Shower Niche Advice
Greetings,
First time trying to do this, so be gentle. I'm tiling a tub/shower wall using 10x20 tile with 2 separate niche areas. I tiled the niche areas first, then did the wall. Unfortunately, I did not account for the thinset thickness and the niche walls are not flush with the front of the tiled wall (see picture). The sides of the niche are pretty close (but not touching) the back of the niche. I was thinking of trying to knock out those tiles, clean the backs/niche walls, and re-set the tile farther forward. I'm concerned though because the tile has been up a couple weeks so it is pretty well set and I'm not sure how hard it will be to pull them. What options do I have to fix this? What do you recommend?
Second, do you recommend grout or caulk for the niche corners?
FYI, it looks like the picture I attached may be rotated for some reason. For perspective, the 10x20 is installed horizontally, not vertically.
Thanks for any help you can provide!
-Brian
