Unread 02-24-2017, 10:24 PM   #1
jphustman
Vinyl Planks in Bathroom
Hello,
I've been searching for a week now and still have not come up with a definite answer, so I am hoping to get some advice from some real professionals I bought this vanity from Home Depot. We want to put these "Luxury" Vinyl Planks down, but can't find an answer as to put them down after I take the old vanity out and place the new vanity on top of them, or if I should just install the vanity and place these Vinyl Planks down after and 'up to' the vanity and toilet. I don't mind taking the toilet out and installing these planks to the 'donut,' but I don't want to if it is going to 'secure' this floor and cause it to buckle.
So, what are the opinions here? Vinyl Planks first, and then the vanity and toilet -- or install the vanity and keep the toilet in and just install up to and around these things.
Cant post links yet so here are the text links.
Vinyl Planks - home depot dot com /p/Home-Decorators-Collection-6-in-x-36-in-Stony-Oak-Grey-Luxury-Vinyl-Plank-20-34-sq-ft-case-60198/207047495
Vanity - homedepot dot com /p/Glacier-Bay-Woodbrook-30-5-in-W-Vanity-in-White-Washed-Oak-with-Cultured-Marble-Vanity-Top-in-White-with-White-Basin-and-Mirror-WB30P3-WO/300209132
Jeremey
jphustman is offline   Reply With Quote
Unread 02-25-2017, 12:44 AM   #2
PetrH
vinyl planks can be installed either way. In new construction I put them down before the cabinets, for renos I cut to the cabinets. Because it's possible to cut planks very precisely, there is little difference. Either way, you need to pay a lot of attention to prep, the floor needs to be 100% perfectly smooth. This is usually done with a combination of sanding and patching and a difficult DIY task. seriously, even a grain of sand is enough to telegraph through some planks.
I always do a full spread of pressure activated adhesive even if the manufacturer rates the planks for loose lay.
I also refuse to install any click together planks, they have proven over and over to be a bad idea.
Petr
Unread 03-11-2017, 11:44 AM   #3
jphustman
Thank you, I am going to replace the vanity first, and then cut the flooring around the vanity, but under the toilet. I will post some before/after pictures. Wish me luck!
Jeremey
Rebuilding Bathroom - Tub to Shower - Old thinset/vinyl question pintnight Tile Forum/Advice Board 2 11-19-2013 12:13 PM
How to replace vinyl tiles glued to wood sub-floor in bathroom Ceceil Tile Forum/Advice Board 6 10-22-2010 07:00 AM
John's Bathroom - tile over vinyl over concrete JohnB1948 Tile Forum/Advice Board 3 09-09-2010 11:53 AM
Ceramic Over Vinyl SMALL Master Bathroom Gigi1 Tile Forum/Advice Board 8 03-30-2009 03:51 PM
Bathroom Remodel over Vinyl flooring Randy Cook Tile Forum/Advice Board 4 09-05-2003 12:43 PM
