Unread 10-09-2015, 04:07 PM   #1
mwpeel
Tile planks
I am preparing to lay 1000sq ft of 6x24 tile planks using the RLS leveling system with 1/8" grout line and not sure how many of the RLS clips I will need.
Can someone help
mwpeel is offline   Reply With Quote
Unread 10-09-2015, 04:24 PM   #2
6x24 tiles cover 1 sq ft each. If you want to use a clip under every corner, that would be 4000.
I would check the tiles to see how flat they are. Place 2 tiles face to face and see if there are any gaps between the tiles at the ends. In my opinion, with tiles that aren't flat, using a leveling system to pull up the corners flush with the neighboring tiles may not help with lippage.
Unread 10-09-2015, 04:32 PM   #3
Ron
Tile Contractor
Hi Mike,
You're going to need a lot. On that size tile you will need 4 on a side, if it is like a random hardwood look, and one on the end. Five pieces per tile. The adjacent tile's levelling clips and wedges will be against the other sides of said tile. A 6x24 is a square foot so you'll need to buy 5000 clips and figure on getting about 600 - 700 of the reusable wedges. I say 600 because you probably won't set more than 120 sq ft in a day.
Ron
Terra Firma Tile
Ron is offline   Reply With Quote
Unread 10-09-2015, 04:33 PM   #4
I used four per tile on my own house, which is the same size tile as yours.
You won't use quite that many on every tile, since you don't count the edges against the walls, but it'll be close to that.
Unread 10-09-2015, 04:35 PM   #5
Ron
Tile Contractor
I'm a slow typist. I really wanted to be first to answer. Davy!!
Ron
Terra Firma Tile
Unread 10-09-2015, 04:39 PM   #6
Ron, next time review your post and scroll down before you hit submit and you'll see if I beat you to the punch. You have no excuse, I only use two fingers to type. A chicken pecker.
Unread 10-09-2015, 04:43 PM   #7
Ron
Tile Contractor
Thanks... and the Blue Jays lost to Texas again too.
Ron
Terra Firma Tile
Unread 10-09-2015, 04:46 PM   #8
That's good news.
Unread 10-10-2015, 05:29 AM   #9
mwpeel
Thanks everyone.
Thinking of tile planks for the Main portion of the house...(NW Suburbs of Chicago) Reefgeek Tile Forum/Advice Board 14 04-07-2014 03:08 PM
Wood tile planks with linear shower drain jim mclaughlin Professionals' Hangout 9 04-19-2012 06:44 AM
1.5" thick planks - how much more subfloor wood do I need for tile? Ron in Seal Beach Tile Forum/Advice Board 3 03-04-2012 08:24 AM
Long and narrow subway tile, or planks dsellinger Tile Forum/Advice Board 4 07-30-2007 11:32 AM
Thanks, planks & shanks Gyroguy Tile Forum/Advice Board 21 11-25-2002 11:07 PM
