Unread 04-11-2020, 05:43 PM   #1
NewAtThis
Needing help
Not sure if this is even the place to start. However maybe someone can guide me in the correct direction. Bought my house about 9 years ago. The main bathroom has I believe to be slate tiles on the floor and shower. About year ago they started flaking off when wet. How do I fix that? Like I need step by step directions lol
First two pics are of the shower. I know it needs new caulk
Last pic is the floor. I know it needs new grout.
Thx for any tips or advice
Tracy
NewAtThis is offline   Reply With Quote
Unread 04-11-2020, 06:44 PM   #2
Welcome to the forum, Tracy!
I’ll get right to the heart of the matter, even though you’re not likely to be happy to hear it. What’s happening is referred to as spalling. As pretty as some material is, not all of it is suitable for a wet environment. And many of the tiles that look like and are sold as “slate” are not suitable for such. I’ve seen a whole lot of “slate” that’s falling apart in a wet shower. Many of the “slates” being sold today are much closer to very hard mud than they are to actual slate. Unfortunately, there isn’t a sealer or a chemical or a process that can stop this from continuing. The permanent fix is to replace the material that’s suitable.
The pictures aren’t clear enough for me to see, but I’m wondering about the shine. Are the tiles on the floor or in the showers shiny?
And the floor tile that’s missing grout is a big red flag that something has gone wrong. This isn’t a normal “wear item” that needs replacing from time to time. Grout should be permanent and last the life of the installation (easily 50+ years). Usually when grout is missing, it’s an indication that the floor is deflecting too much for the stiff grout to tolerate and causes it to very slowly grind onto itself and powder away. In addition, natural stone on the floor has a special minimal requirement to be twice as strong/stiff as that which is needed for man-made ceramic/porcelain tiles. This requirement to have a floor deflection of L/720 is quite unusual (floor that deflects no more than 1 unit of measurement downward for every 720 units of measurement laterally), as it requires pre-planning of the joists before construction of the house to make them strong enough...very few houses have joists this stiff.
I know this is a lot to take in, so please feel free to come back with any questions.
Unread 04-15-2020, 12:49 PM   #3
NewAtThis
The tiles that get no water are shiny but not the ones that come in contact with water
Tracy
Unread 04-15-2020, 03:48 PM   #4
fhueston
Only remedy is to tear it out and replace with something suitable
Fred
fhueston is offline   Reply With Quote
Unread 04-16-2020, 09:07 AM   #5
Hi Tracy,
I have to agree with Bubba. I've seen a lot of sedimentary material that hasn't quite morphed into slate, and it appears that's what you probably have. There is really no cure for it.
First Timer Needing Some Advice bej0520 Tile Forum/Advice Board 5 02-26-2014 04:34 PM
Needing to cut hole in Graniteware pan. rangerman942 Tile Forum/Advice Board 5 12-31-2013 02:06 PM
Newbi needing some pointers Jamie123 Tile Forum/Advice Board 5 07-25-2012 12:27 PM
First timer needing some help! MidKnight Cleaning, Restoration and Sealing 2 05-05-2011 04:50 AM
Needing Help With Durock Installation lgsmith77 Tile Forum/Advice Board 13 06-26-2003 07:53 AM
