Unread 07-16-2019, 07:56 PM   #1
Panama
Grout in calcutta gold herringbone shower floor showing rust
The grout in my new shower floor (calcutta gold herringbone) is turning a rust color and pitting. So much of the grout is pitting and showing cracks. The marble is not showing any rust, just the grout. Suggestions? It has only been in 3-4 months. NO chemicals are used for cleaning and a squeegee is used after each shower.Name:  IMG_1667.jpg
Panama
Panama is offline   Reply With Quote
Unread 07-16-2019, 09:26 PM   #2
Welcome to the forum, Panama!
Couple things going through my mind. But let's start with:
Do you have any idea if the tile was set with a material that came pre-mixed and ready-to-use right out of a bucket? Or if a powder was mixed with water or a milky liquid to make the mortar in batches, as batches?
Unread 07-17-2019, 05:21 AM   #3
Panama
It was a powder mix for sure. Sand-free laticrete since it was applied with with the marble floor.
Panama
Unread 07-17-2019, 08:14 AM   #4
fhueston
this is a common problem with white marble. They contain iron and when exposed to moisture the iron starts to oxidize. I see it all the time.
Fred
fhueston is offline   Reply With Quote
Unread 07-17-2019, 08:37 AM   #5
Panama
The marble in the herringbone floor has not turned colors, the grout has turned rusty and the grout has pitted so bad.
Panama
Unread 07-18-2019, 08:29 PM   #6
Do you know the manufacturer of the grout, and the color?
Unread 07-18-2019, 09:38 PM   #7
Don't know the color, but from post #3 it's " Sand-free laticrete" grout, Kevin.
I'm curious to know how wide are the grout joints. Can't really tell what size those tiles might be without any perspective in the photos.
Unread 07-19-2019, 07:25 AM   #8
I thought he was referring to the setting material, since that's what Bubba was asking about, but you're probably right.
Unread 07-19-2019, 07:37 AM   #9
Flyingscot
Maybe I'm crazy but that looks like pink mold to me. We have it in my region. I'm also seeing what looks like mildew in the caulk.
Lynne
Flyingscot is offline   Reply With Quote
Unread 07-19-2019, 07:38 AM   #10
Yeah, you could be right, Kevin, but looks like she ain't comin' back to tell us one way or the other.
Does Laticrete have an un-sanded thinset mortar these days?
Unread 07-19-2019, 08:06 AM   #11
Yes, Panama, please clarify. It sounded like you were inadvertently describing the grout in post #3, rather than the setting material. I want to make sure the setting material was also a powder mix and not something pre-mixed from a bucket.
Unread 07-19-2019, 08:08 AM   #12
Flyingscot
It looks exactly like what happened when I stupidly used mastic for a tiled shower floor years ago. The discolored grout was mold.
Lynne
Unread 07-19-2019, 09:09 AM   #13
Yeah, you need solid support under the tiles. If mastic was used, it might not be dry and rock hard. And this would lead to discoloration and slightly rocky tiles from foot pressure that could leave cracks around some tiles.
Unread 07-21-2019, 01:00 PM   #14
Panama
I apologize...my computer was down and I finally got it working!
The color of the grout is LIGHT PEWTER, LATICRETE 1600 UNSANDED GROUT. It was a powder mix. The joints are 1/8". I can take additional pictures if it would help. Thank you all so much!
Panama
Unread 07-21-2019, 01:02 PM   #15
Panama
This is the marble I used in the shower-- Calacatta Gold Herringbone Italian Marble • Finish: Polished • Each sheet cover one square foot • 8 Columns by 8 Rows • 64 Stones per Sheet • Sold by the square foot • Thickness 3/8" (10mm) • First Quality
Panama
Calcutta Gold floor help Derek1234 Tile Forum/Advice Board 6 08-01-2014 03:01 AM
calcutta gold TRAVIS (I.T.M.) Cleaning, Restoration and Sealing 2 04-26-2012 06:31 AM
Cracked Calcutta Gold sanjeev Tile Forum/Advice Board 7 06-23-2008 09:52 AM
Calcutta Gold and epoxy Deckert Professionals' Hangout 1 05-31-2008 03:21 AM
cracking calcutta gold marble floor tarheel Tile Forum/Advice Board 20 07-17-2007 09:16 PM
