Old 11-05-2018, 10:14 AM   #1
rgrandy
Cleaning Flexcolor CQ
I just completed a kitchen floor using American Estates Spice 6x36, wood look alike tile and Flexcolor CQ grout. It looks very nice, but I did have some trouble cleaning the grout haze off of the tile and there is quite a bit of haze left.
I bought some epoxy haze remover and my question is, what is the best method to clean the tiles?
Can I use a sponge and scrub everything? Do I need to use a rag and only touch the face of the tiles? How long should I leave the product on? Any other tips? I don't want to affect the grout lines at all but some areas need to be cleaned quite a bit.
Ryan
rgrandy is offline   Reply With Quote
Old 11-05-2018, 08:53 PM   #2
Ryan,
Got pics?
How grippy is the tile?
Old 11-06-2018, 06:15 AM   #3
rgrandy
It is definitely not "smooth" tile there is a fair bit of texture to the tile.
In places I got lazy I can still see grains but in most places it is just haze.
I attached some images (I don't think the grout photographs well, it must catch a lot of light, it looks really gray in the images but in most light it is pretty well matched to the tile color in real life)
Ryan
Old 11-06-2018, 06:50 AM   #4
rubbing a dry green scratch pad over the tile will highlight where you missed the "grit" and a wet one will get it off. As for the haze, windex works really well and a razor blade and the green scratch pad. I would test it on a spare tile first and make sure it will not scratch the finish
Old 11-06-2018, 06:08 PM   #5
I wouldn't use a green one as he green color can get into the grout.
Use a white one instead.
Latex paint remover sprayed over the top, let that dwell a few minutes, scrub with the white pad, wipe with sponge, wipe with sponge covered in a quality microfiber.
Old 11-06-2018, 07:13 PM   #6
Originally Posted by Houston Remodler
I wouldn't use a green one as the green color can get into the grout
I have never had that happen and I do it all the time. Have you had this happen? I have had windex put a blue tint on avalanche. Not noticeable unless you were right up on the tile
Old 11-06-2018, 08:40 PM   #7
Yeah, seen it a number of times.
Old 11-07-2018, 12:41 AM   #8
rgrandy
Does this mean that the tiles should not be cleaned later in time with Windex or similar as it may remove a layer of the grout?
Ryan
Old 11-08-2018, 06:08 PM   #9
Ryan, I believe they are talking about the windex staining some grouts a light blue. I would try the Krud Kutter Paul mentioned or another product called Lift off. I can't remember who makes it but Home Depot has it. I've sprayed Lift Off on a Micro fiber rag and wiped haze off before. I've never had it stain grout.
I wouldn't use Windex for daily cleaning.
Old 11-08-2018, 08:07 PM   #10
Ryan I was saying that I have had windex put a blue tint on the color avalanche, which is the whitest grout they make. With your dark grout I wouldn't think that would be a issue. Sorry for the confusion
Old 11-08-2018, 09:07 PM   #11
rgrandy
Sorry for the confusion, I was asking about if I would need to be careful about which cleaning supplies I use on urethane grouted tiles. If I repeatedly used Windex or something similar would it over time erode the binder in the grout? I am planning to use flexcolor cq for backsplash and I imagine I will be wiping it down with a cleaner a lot.
Ryan
Mapei Flexcolor CQ nelsonkoehn Professionals' Hangout 423 04-01-2019 09:00 AM
Mapei Flexcolor 3D MudMaker Professionals' Hangout 46 08-01-2018 07:30 AM
Flexcolor CQ Cleaning browndo2 Cleaning, Restoration and Sealing 1 12-23-2016 05:00 PM
Flexcolor CQ amyintx Tile Forum/Advice Board 10 08-22-2015 09:15 AM
Need a bucket of Flexcolor CQ Colabear Professionals' Hangout 4 11-04-2014 12:57 PM
