Old 04-28-2010, 11:55 AM   #1
Kuebes
Deflecto Question (I Joist)
Hello...I am looking for some advice on deflection. I have to lay pocelain tile on a kitchen floor in a Hopscotch pattern (12"x12" and 6"x6"). The subfloor is 3/4" plywood. It has "I" Joists that are 24" apart. the longest span is 10'.
Can I lay 1/4" durock (thinset and screwed) then lay this tile or should I install a layer of 1/2" plywood as well as the Durock? I tried the deflecto tool but it does not have an option for "I" joists.
Thanks for any advise you can give. I tried searching for a similar post but could not find.
Mike Kuebs ("Cubes")
Kuebes is offline   Reply With Quote
Old 04-28-2010, 02:03 PM   #2
Mike, our deflecto tool works with sawn lumber only. The I-joist manufacturers have their own ways of calculating the deflection ratings, so it's best to find out who made yours and as their tech support engineers. We have a few links to some of the bigger players' span tables in the Liberry. A word of caution: read the fine print! Lots of qualifications and modifiers there.
As far as your subfloor is concerned, more plywood is needed, but I don't think your choice of backerboard will work. The backerboard folks have been slow to embrace joist spacings wider than 19.2". However, Ditra can be installed in your situation. They require 3/8" plywood over 3/4", so you can save about 1/4" of height in the process.
Old 04-29-2010, 08:41 AM   #3
Kuebes
Thanks for your advise Bob. I will do my research.
Deflecto Question Cheech Tile Forum/Advice Board 6 01-11-2010 01:26 PM
Using Deflecto for sistered joist mrjetskey Tile Forum/Advice Board 2 04-26-2007 08:20 AM
joist say silent floor on them. what do I use in the deflecto? cas Tile Forum/Advice Board 2 10-23-2006 08:59 PM
Deflecto Question dbrodish Tile Forum/Advice Board 1 04-13-2005 07:02 AM
Question about Joist Length in Deflecto Unregistered Tile Forum/Advice Board 9 11-15-2004 03:42 PM
