11-12-2012, 08:43 AM
#15031
here is a pic of it in use.
I'd like a way to mount the crank portion on a pole.
Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
11-12-2012, 02:08 PM
#15032
what if you dont have 2 buckets with lids on them ?
11-12-2012, 04:45 PM
#15033
CTEF Director
Hammy, you need to get some Zip Poles if you don't have some already, and when you do you could lash that whole set up to it with velcro straps or flat bungees.
That way you could get to sittin on dem buckets.
Brad
11-12-2012, 06:15 PM
#15034
Hammy, you do know that those tripod legs pull out further, right?
11-12-2012, 07:46 PM
#15035
Making Cents of It All
I have the same type of tripod in the trailer but most the time I just wing it and set it up on whatever is around.
11-12-2012, 08:05 PM
#15036
Is that the same setup you use to reach to tile the ceiling....
11-12-2012, 10:26 PM
#15037
Tile Contractor
Originally Posted by Chad
Greg does that pole has a fine tune adjustment. When I'm setting my laser up I usually have to fine tune the height with anything laying around to get the height right on the money.
Chad, you basically loosen a screw knob and slide it up and down wherever you need it. There is a scale onna side with graduations down to 1/16". It is so convenient, and such a time saver, I couldn't imagine building a shower without it.
The name's Greg
11-12-2012, 11:20 PM
#15038
SchluterUgrad
This is the one I use. 3rd Hand pole and magnetic laser mount.
Only adjustment is sliding the magnetic gripper up and down. Magnets are really strong. No slip here.
http://www.fastcap.com/estore/pc/Mag...Mount-3p25.htm
11-13-2012, 08:35 AM
#15039
Nice thanks Greg. You must have rechargeable batteries in that thing.
11-13-2012, 07:29 PM
#15040
I use a piece of tile as a bucket lid. Or a piece of plywood. But I always have bucket lids.
Brad
Brad, I need to do something better.
Hammy, you do know that those tripod legs pull out further, right? Tiger
Yea, I know but the tri pod is only 48" tall. Besides with the legs extended it takes up too much room.
Is that the same setup you use to reach to tile the ceiling....Jondon
Yup it sure is.
On one job ( new construction ) I screwed a shelf to a door frame and set the tri pod on it. Moved the shelf as needed. Worked real well.
Hammy
11-14-2012, 01:20 AM
#15041
Tile and Stone Contractor
Hammy's bucket tripod is just good old fashioned southern ingenuity.
11-14-2012, 07:09 AM
#15042
LT
I used to dream of running multiple large projects.The dream is turning into a nightmare.....
*L.T.*
tandctile-dot-net
2nd generation tile installer
11-14-2012, 10:14 AM
#15043
I've had the same experience.  but to get to where I want to be I have to try it again.
Looking back I realize that the failures were really my fault. I didn't set things up correctly, I didn't communicate properly, and I didn't put the right guys in the right places.
My problem is that I'm a neurotic perfectionist and am always worried about the image that my business projects. The easiest way to control it is to do everything myself, but then I'm stuck.
11-14-2012, 04:26 PM
#15044
Some pics of a job I an on where the carpenter told HO he'd do the job for 1/2 of what I quoted for labour. Used tornados for the marble, no noticeable scratches, now just the ensuite bathroom and shower, the travertine chiseled edge versailles pattern entrance and mud room.
Dale
Better with mud and tiles than computers and smartphones.
11-14-2012, 04:33 PM
#15045
Missed the one of the marble, and won't upload now,will try later.me and my not so smart phone are not getting along very well right now.
Dale
