glass mosaic backsplash onto painted drywall... prime?
I bow to the fellow Experts. You are the greatest and I need your help.
I was about to start putting up a glass mosaic backsplash in the kitchen, did layout - woohoo, it took me an awful while with nipping/snapping/filing and cutting schluter edging profiles. But being concerned about the wall prepping (too much of contradictory advice of all sorts all over the web) I did a duct tape test that I found on youtube [ v=NEioEiASU7w ]. I put a piece of duct tape on the wall, pulled it and some coating peeled off. So, following the recommendations I started scrapping it off in panic - I want my backsplash to last!!! Now...
SITUATION:
1) It is an old drywall, used to have seamy-gloss on, I TSP cleaned it and primed / sealed (Kiltz and/or Roman Rx-35 - the wall was disgusting behind old cabinets, so i sealed it all)
2) One wall has a few inches pained at the top - I originally planned to have the tile go lower. The paint is dark gray. Glass tile is translucent with white backing.
3) Not all the walls have the paint/sealer pealing off with duct tape as easily. I started scraping off the worst one. Others had a tiny bits of paint come off
4) In one corner the tile will go as high as 26" - corner with dark gray paint, about 28"x11" in length. Paint doesn't peel off as easily there.
5) wall that peels off easier has a large window above the sink with about 14" on each side.
MATERIALS:
a) glass/ceramic mosaic tile by Jeffrey Court
b) 1" x 2" subway tile for edge by the door (5 tiles wide)
c) Glass Tile Premium Thin-Set Mortar by CustpomBuilding
d) have some KILTZ primer
e) LASTLY, I have AcrylPro ceramic tile Adhesive by Custom, which I understand it is not recommended for glass no matter how small individual tiles are. BUT, contractors that installed the same tile on the opposite accent wall used it while I wasn't watching even though I had the right thin set for them.
QUESTIONS:
1) Shall I keep scraping off the paint/sealer? All over or only where it comes off easier?
2) Shall I prime before I start tiling? The wall under te paint is a bit chalky (may be that's why paint/sealer peeling off). There was some patching done after electrical work.
3) shall I white-prime over the painted wall, so the color wouldn't "bleed" through? I have no idea what the backing of the translucent white tile is - I soaked it in water, tried to scratch and wasn't able to.
4) shall I use different thinset for ceramic subway and glass mosaic?
4) LASTLY: shall I just use the same mastic that was used by contractors on the accent wall? My concern is the color. I was told that mastic might result in tile turn yellow, and with paranoid eye, almost can see it in places at certain angle (accent wall was installed 4 months ago)
Svetlana
