Unread 12-20-2013, 01:02 PM   #1
xazilizax
BIG DILEMMA!!! Need help removing mosaic backsplash in kitchen.
So, my mother decided to take on a big project she couldn't handle herself, so now I am here for the holidays trying to help her remove this disaster backsplash boo boo she did. Luckily, she didn't mess up the entire kitchen, but it's big enough to shake my head in despair. lol
In these 2 photos, you can see the big mess. (Yea, I also need to help her paint.) The other pic is of the sticky product she used to stick the backsplash onto the wall. I don't know what to do. It's hard to break off the mosaic (which I managed to break off a few) and then peel off the sticky thing from the wall.
HELPPPPPPP!!!!!!!!!
xazilizax is offline   Reply With Quote
Unread 12-20-2013, 01:16 PM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Any grout in there?
I have a couple of these I use for all kinds of removal tasks.
http://www.amazon.com/Shark-21-2225-.../dp/B0000224TY
The broad back allows some leverage without punching holes in drywall. I'd start there. The super-flypaper may be tougher. It may prove easier to "split" the paper face on drywall and just figure on doing some patching. My guess is it's pretty stuck but a stiff putty knife would be where I'd start. I've even turned Shark over and used it like a scraper.
Experimentation will tell you where to go. What are your plans after removal?
Peter
Unread 12-20-2013, 01:20 PM   #3
xazilizax
Yep! There's grout in it.
Well, I told my mother NOT to touch the kitchen anymore without asking someone for help. haha
I'm just going to help her paint. Nothing else will be done to it for now.
I really don't want to damage her wall. I don't know too much of what I'm doing when it comes to walls, so it will be a little scary for me if I'll be putting holes in her wall. Ugh!
Liza
Unread 12-20-2013, 02:41 PM   #4
Bodie Powers
Retired cabinet maker/remodeler
Bodie Powers's Avatar
We use a Vaughan Super Bar....the pry head is angled for vertical applications, and is wide which is good for tile removal. Put it in position then give it a whack with a hammer.
Bodie
Bodie Powers is offline   Reply With Quote
Unread 12-20-2013, 03:36 PM   #5
Welcome, xazilizax. Please change that permanent signature line to a first name for us to use.
Unread 12-21-2013, 06:04 PM   #6
sancyk
Once you have removed the tile, maybe a hair dryer can be used to soften the adhesive enough to peel off that membrane.
Chucky
sancyk is offline   Reply With Quote
Unread 12-21-2013, 06:22 PM   #7
Liza, you might wanna contact the manufacturer of that product to see if they know what chemical might loosen their adhesive. I've never seen the product and ain't got a clue.
Or start with the FAQ section of their website.
Unread 12-21-2013, 06:39 PM   #8
I'd experiment with a hair dryer on the exposed flypaper stuff to see if that assists in removing it. If it comes off, then I'd proceed with a relatively thin putty knife positioned at a super shallow angle (so it doesn't want to penetrate into the drywall) between the drywall and tiles. Tap the top of the handle with a hammer to drive the putty knife forward to separate the tiles. Do protect yourself and the area from the breaking glass.
If that doesn't want to work, you could just remove the drywall (tile and all) and replace it. Cut around the perimeter of the tile and pull it out. If you can't make the "bottom cut" along the countertop because the tile is in the way, make the top and whatever side cuts you can make and pull the board forward...it will break small or large sections of drywall out at a time. Not exactly clean, but could be pretty effective. Drywall is cheap, so this might be an attractive option over trying to slowly remove and clean the tiles.
Mosaic Glass Backsplash for Kitchen t2jeff Tile Forum/Advice Board 45 11-01-2013 07:38 PM
removing backsplash in kitchen dawny Tile Forum/Advice Board 12 04-28-2009 02:20 PM
Removing mosaic tile backsplash Brookness Tile Forum/Advice Board 8 07-14-2006 08:32 AM
removing kitchen backsplash pkcopper Tile Forum/Advice Board 1 01-01-2005 01:51 PM
a mosaic kitchen backsplash Phyllis Tile Forum/Advice Board 4 06-05-2004 11:24 PM
