Unread 06-04-2010, 07:31 PM   #1
RodCloutier
Calculate deflection with sistering
Hi,
If I have "sistered" joist, full span. How do I use the deflecto tool? Should I just add the width of both joists and use it as the effective width?
Rod
RodCloutier is offline   Reply With Quote
Unread 06-04-2010, 08:08 PM   #2
Welcome, Rod.
If the two joists are the same size, just add the thickness and use that in the calculation.
If not the same size, do the calculation for each size and add the results.
plywood sistering to improve deflection justin case Tile Forum/Advice Board 7 12-17-2009 06:55 PM
sistering joists for decreased deflection scottg Tile Forum/Advice Board 2 04-13-2006 08:47 PM
Deflection: Sistering effectiveness of... jdkimes Tile Forum/Advice Board 14 05-31-2005 09:57 PM
deflection after sistering WAV Tile Forum/Advice Board 26 04-07-2005 11:35 AM
How to calculate wmw Tile Forum/Advice Board 1 02-03-2004 07:31 AM
