Unread 06-12-2006, 03:50 PM   #1
joe14580
Swanstone tub surround - easy question !!!
What side faces the user: the "shiny" side, or the "duller" side ?
It's three-piece unit. The instuctions say that a sticker should be affixed the the side that goes towards the wall, but only one piece had a sticker, so the factory doesn't seem too concerned.
The piece I'm installing has a sticker that seems to be on the "shinier" side. However the shinier side also "seems" to be more bumpy, by feel, and in particular when you hold a bright light in front of it. Although you'd expect the bumps to show up (visually) more on the shinier side.
Anyways, you guys were a great help b 4 with my noobie floor tile questions, and Swanstone is closed for the day, so I'd thought I'd check in here and see if anyone had a definitive answer. Beside, even if I elect to call the factory, I'm never really sure about the knowledge of the folks that answer the calls.
Thanks.
Joe
joe14580 is offline   Reply With Quote
Unread 06-12-2006, 04:32 PM   #2
jdm
jdm's Avatar
I'm no Swanstone expert, but the samples I remember seeing all had a very smooth satin finish, not a shiny bumpy one. So I suspect that the label is on the back of the one piece.
jeff
Go Rutgers!
Unread 06-12-2006, 06:24 PM   #3
Jeff has it, the smooth satin side is what you want to see. The slightly bumpy side is towards the wall.
Unread 06-13-2006, 10:06 AM   #4
joe14580
I called Swanstone, they said it used to matter which side was facing out, but it doesn't anymore due to a change in manufacturing. Now, it's up to the tastes of the customer. I agree, that satin side looks best facing outwards.
Thanks.
Non-tile question: Swanstone panels mgb2 Tile Forum/Advice Board 3 01-09-2015 06:41 PM
Swanstone shower pan install question bclinton Tile Forum/Advice Board 8 01-08-2014 02:25 PM
swanstone floor pan question kathygr Tile Forum/Advice Board 3 12-16-2011 10:01 AM
Swanstone tub surround cliftonite Tile Forum/Advice Board 7 11-18-2011 01:45 PM
Swanstone shower pan framing question pahiker Tile Forum/Advice Board 17 02-15-2009 12:01 PM
