Unread 01-28-2006, 10:12 AM   #1
medik13
building out wall to be even with tile
Hello all!
I just recently had my Master shower tiled with 1/2" marble. the installer used about another 3/8" - 1/2" of setting material and bullnosed the end pieces. However the setting material is seen and sticks out 1/2" past the greenboard that is jointed to the durock.
What can I do to build out the wall so it is nicely finished to the bullnose. Can I add another 1/2" sheet of drywall ontop of the greenboard, or should I build out the wall with 1/2" inch of two coat veneer plaster?
medik13 is offline   Reply With Quote
Unread 01-28-2006, 01:50 PM   #2
muskymike
muskymike's Avatar
Hi there, welcome! Gotta first name we can use? You can add the drywall. They should have 3/8" dw too if the 1/2" is too much.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 01-28-2006, 04:37 PM   #3
medik13
3/8"??? All I have around here is 1/2. Where can I get 3/8? Thanks for the reply...
Sean
Unread 01-28-2006, 05:24 PM   #4
Hi Sean, Welcome aboard.
Don't know where you are. 3/8 sheetrock is quite common. Home Depot has it from time to time. A drywall supplier in your area will certainly have it.
Unread 01-28-2006, 05:27 PM   #5
davem
davem's Avatar
Yep what John said, I got 8 foot 3/8" at HD a couple weeks ago. Welcome Sean.
davem is offline   Reply With Quote
Unread 01-28-2006, 08:47 PM   #6
medik13
I can just secure it to the studs over existing greenboard, correct??? WOW...Thanks for the welcome and speedy replies!
