Unread 11-26-2020, 02:51 PM   #1
Joe_A
Tiling a half wall with 3 faces
Hi Everyone, I’ve been reading the forum and there is plenty of great knowledge.
I’m stuck on how to tile a short wall with 3 facing sides. Top, shower facing side and vanity facing side. I’m using 4x12 Carrara ceramic tiles. Only available trim is 4x12 with the bullnose on the 4” side.
Fourth side, toilet facing will be smooth and just painted.
I tried tinkering with schluter and could not figure out the 3 way outside corner intersection. Plus my miters didn’t come out well.
I can bullnose the sides but what do I do about the shower/vanity facing corner?
Any suggestions are appreciated. Especially pics. Definitely a visual learner.
TIA,
Joe
Joe
Joe_A is offline   Reply With Quote
Unread 11-26-2020, 04:56 PM   #2
Tile & Stone Guild
King Of Tile
You can rip the bullnose into equal widths. Schluter sells outside corners and inside corners if you buy the rondec. You just have to make straight cuts to the corner.
Jeff
Unread 11-26-2020, 06:05 PM   #3
Welcome, Joe.
Is there a shower in this tub enclosure?
Is it just the photo, or does that tub extend out further than that short wall?
Unread 11-26-2020, 06:42 PM   #4
Joe_A
Thanks. I’ll take a look. Home Depot is only 5 minutes away so I tend to focus on convenience.
Joe
Unread 11-26-2020, 06:45 PM   #5
Joe_A
Yes there is a shower. The half wall is the back of the shower/tub stall. There are two walls tiled with the 4x12. The entrance side is a 36” frameless door. No water splashes out. This is the same layout as before just a cosmetic upgrade. 10yr ago when I was a real amateur I used slate and had an unfinished live edge.
Joe
Unread 11-28-2020, 04:22 PM   #6
This is a similar situation. I used a slab piece on top and wrapped the joints all the way around the 3 walls. BN was available on the long and short sides so that helped.
Unread 11-28-2020, 07:20 PM   #7
CaliGrown
CaliGrown's Avatar
Very Nice and tidy work Davy!!
I’d wager to bet that the pony wall took more time than it did stacking your main walls.
Christopher Machado
1 (916) 990-1751
Unread 11-28-2020, 08:57 PM   #8
Just In Tile LLC
Just In Tile LLC's Avatar
Sometimes I'll schluter things this way and only make one miter from the top to the front. Maybe an option for you?
Justin
Just In Tile LLC is online now   Reply With Quote
Unread 11-28-2020, 09:00 PM   #9
Demonic
Man that's some nice work Davy and Justin.
Austin
Demonic is offline   Reply With Quote
Unread 11-28-2020, 09:14 PM   #10
Just In Tile LLC
Appreciate that Austin
Justin
Unread 11-29-2020, 11:16 AM   #11
Tiger Mountain Tile Inc
This is another way of doing it.
For cutting this stuff, you can use a hack saw with a miter box. Another way to go is to use a chop saw with a non-ferrous metal blade.
Personally, I like this blade as opposed to the kind with teeth because those teeth can catch on the webbing and rip it out of your hands. It's best to cut the webbing away and using a chop saw makes nice, clean cuts.
Unread 12-04-2020, 12:41 AM   #12
Joe_A
Very cool stuff. Thanks everyone for the pics and suggestions.
I’ll post a pic when I finally finish.
Joe
How to plumb half wall before tiling drewbeh Tile Forum/Advice Board 4 09-11-2017 08:39 PM
Advice on tiling prep for 4' shower half wall - lath support needed? alphabeta Tile Forum/Advice Board 21 07-24-2014 08:06 AM
Half Wall / Knee Wall for shower SethAMG Tile Forum/Advice Board 10 04-29-2014 01:33 PM
half wall between shower and tub johnm sr Tile Forum/Advice Board 6 10-14-2009 06:41 PM
Tiling top of half wall in shower jthoni Tile Forum/Advice Board 2 02-24-2008 10:19 AM
