Unread 06-15-2020, 03:32 PM   #1
NJDSG
Gap between tile and shower drain
I've been ignoring this for a while and really need to fix it. I assume there was grout there at one time and it cracked and went down into the pan. What are my repair options without removing the drain? I do have left-over tile from the original install.
Matt
NJDSG is offline   Reply With Quote
Unread 06-15-2020, 04:09 PM   #2
Lazarus
Lazarus's Avatar
Tile looks pretty close. I would clean it up a bit, mix some some grout and just re-do it......
Unread 06-15-2020, 05:30 PM   #3
NJDSG
Thanks. I'm a relative newbie with grouting and still need to educate myself on the differences, whatever they may be, between different brands and types of grout. A while back I bought the pre-mixed shown below. Is this adequate?
Matt
Unread 06-15-2020, 06:19 PM   #4
If the area is dry and the grout joint is within the min/max width, yes, that should work. Most of the time to regrout, they say you need to dig out the old grout to at least 2/3'rds of the depth so that there's some tile edge to adhere to. Some of the one-part ones can handle less, but only if you're going over the same material, not over a cement based grout.
Note that the color may not match really closely. It might with an epoxy or a one-part grout, but not to a cement based one where the color, even from the same bag, can differ as to how well it was mixed, and the amount of water.
Unread 06-15-2020, 07:20 PM   #5
NJDSG
Ok, I appreciate the explanation Jim. The joint is within the min/max width, and it looks like there's enough tile edge exposed.
According to the specs, you have to wait 7 days before water exposure when used on shower floors. Ugh. Is that typical of most grouts?
Matt
Unread 06-15-2020, 07:28 PM   #6
I wouldn't use that grout on a shower floor. Custom makes cement based grouts like Prism (Home Depot) that in my opinion would be a better choice.
Unread 06-16-2020, 07:39 AM   #7
NJDSG
Thanks Davy. I'll check out the Prism.
Matt
Shower drain sits low. Can I try raise drain by twisting it still? Or am I too late? 417linux Tile Forum/Advice Board 20 02-07-2019 09:32 AM
Lead Filled drain in stall shower drain Ravenger Tile Forum/Advice Board 4 03-11-2010 01:52 PM
Moving shower drain and toilet drain ques? iagaoe Tile Forum/Advice Board 11 08-13-2008 12:48 PM
Removing shower drain for Schlutter Drain system teto Tile Forum/Advice Board 7 06-14-2008 05:19 PM
Shower Drain Weep Holes and Drain Canals Electrician Al Tile Forum/Advice Board 1 01-16-2006 09:06 AM
