Unread 04-15-2013, 07:36 PM   #1
Shanawa
Need suggestions on waterproofing slate panels on cmu.
Hello,
I don't have a lot of tile/stone work experience. I plan on building a pond/water feature this summer and am trying to find out a way to waterproof the cmu block wall that has a waterfall in it and still be able to support the weight of the slate and be fish friendly. I was going to originally carry the epdm liner all the way up but I don't think the slate will stay attached to it for long.
This is the the slate tile I am planning to use at this point: M. S. International Inc. Golden Honey Ledger Panel 6 in. x 24 in. Natural Slate Wall Tile ( It wouldn't let me post a link but it should come up in google.)
Here is a picture of my current design:
Would something like Kerdi work for me?
Shan
Shanawa is offline   Reply With Quote
Unread 04-15-2013, 08:03 PM   #2
cwilde72
cwilde72's Avatar
Shan, I would consider a liquid waterproofing membrane for your application such as Laticrete Hydroban.
Chad Wilde
Precision Tile
Huron, SD
cwilde72 is offline   Reply With Quote
Unread 04-16-2013, 10:04 PM   #3
Shanawa
Thanks. That looks like what I need.
Shan
Unread 04-16-2013, 10:15 PM   #4
Welcome, Shan.
Keep in mind that any tile industry direct bonded waterproofing membrane (ANSI A118.10) must be covered with a wear surface after application. I know of none that can be left exposed. And no, your water doesn't count.
Can't tell if you had in mind covering the entire pond surface or not.
Unread 04-17-2013, 06:15 AM   #5
Shanawa
The pond itself will be covered in a epdm liner from the captsones down ( The black space above the water). It was just from the capstone up is where I needed some waterproofing that the stone would adhere to and not fall down.
Shan
Suggestions for Sealing Slate jkelly827 Cleaning, Restoration and Sealing 3 11-19-2010 03:33 PM
Removable Slate Patio Panels artie Tile Forum/Advice Board 4 05-29-2007 06:31 PM
Suggestions for cleaning slate BEFORE sealing slate casamyers Cleaning, Restoration and Sealing 4 08-13-2006 12:52 AM
Vertical slate tiles over exterior cmu notsooldman Tile Forum/Advice Board 1 06-13-2006 05:48 PM
Access Panels revisited, plus grout suggestions? gof Tile Forum/Advice Board 9 04-30-2003 03:55 PM
