Unread 06-12-2020, 10:06 AM   #1
NJDSG
First time replacing grout in shower wall + floor joint with silicone caulk
The grout where the shower walls and floor meet was cracking, so I decided to go ahead and replace it with silicone caulk. I've never tried to remove grout before, so that was an adventure in and of itself.
I'm at the stage of cleaning up the tile at either plane and was wondering about the grout haze shown in the photo. Should I try to remove that before applying the silicone? (Um, yes that might have been left by yours truly when he tried to "touch up" the grout previously.)
Matt
NJDSG is offline   Reply With Quote
Unread 06-12-2020, 10:37 AM   #2
Yes, get it clean first but avoid flooding the joint. Sometimes a dry cloth will remove the haze. If you have to wash it, let it dry well before installing the silicone.
Unread 06-12-2020, 10:59 AM   #3
NJDSG
Thanks Davy. Ok, I'll clean it up before going further.
So far I've tried an acetone dampened rag with no luck. Is there a product that's effective at removing the haze and is safe for stone tile?
Matt
Unread 06-12-2020, 01:58 PM   #4
Hi Matt,
Acetone won't do anything to cement. The tile looks like ceramic to me. If it is in fact stone, as long as it's not marble, limestone or slate you can use sufamic acid, which is available at Home Depot and Lowes. You might try white vinegar and a stiff brush before resorting to the acid.
Do not use any acid stronger than sulfamic.
Unread 06-12-2020, 02:36 PM   #5
NJDSG
Hi John. Thanks for weighing in on this.
I did some digging around and found the extra tiles left over from when this bathroom was done. Looks like it is in fact marble (according to the box).
Some better shots below. Sound like this changes/limits what I can use to remove the grout haze?
Matt
Unread 06-12-2020, 03:46 PM   #6
rmckee84
rmckee84's Avatar
Try a very small area with very fine wet sandpaper and see what that does.
Ryan McKee
Unread 06-12-2020, 04:51 PM   #7
NJDSG
I can do that. How fine do we want to go here? I have 1000, 1500, 2500, and 3000 grit on hand.
Matt
Unread 06-12-2020, 08:39 PM   #8
rmckee84
rmckee84's Avatar
1000 should be fine could probably go a little coarser. Like I said just try a small area first.
Ryan McKee
Unread 06-13-2020, 06:53 AM   #9
NJDSG
Ok, wet sanding a small area with 1000, using moderate pressure, removed a little bit of the haze, maybe 10 percent. Worth trying 650?
Matt
Unread 06-13-2020, 12:28 PM   #10
NJDSG
Moved to 800, and it's very slow going. Of course, it looks good when it's wet and then the white comes back. If this is my only option, I'll keep at it. But if there's anything else I can/should try on marble, let me know.
Thanks again everyone.
Matt
Unread 06-13-2020, 08:21 PM   #11
hatt4556
The haze after sanding may be due to the sealer being sanded off. Especially if an enhancing sealer was used.
Sent from my SM-G986U using Tapatalk
hatt4556 is offline   Reply With Quote
Unread 06-13-2020, 08:33 PM   #12
NJDSG
Interesting. I guess I'll keep at it, since it sounds like leaving any of the haze would interfere with the adhesion of the silicone.
Matt
Unread 06-13-2020, 09:52 PM   #13
Welcome, hatt4556. Please put a first name in a permanent signature line for us to use.
Sanding is unlikely to have any effect on any penetrating sealer or enhancing sealer likely to have been used on a stone tile. Those don't remain on the surface of the tiles.
No caulk or grout where wall meets floor in shower CarpenterLearningTile Professionals' Hangout 0 10-16-2011 01:50 PM
Replace silicone caulk in shower corners/floor-wall joints with grout? lexrn Tile Forum/Advice Board 2 04-22-2008 06:38 PM
Grout or Caulk at tub/wall joint? Randar68 Tile Forum/Advice Board 3 06-11-2007 04:39 PM
Floor to wall joint - Caulk or Grout nagurdj Tile Forum/Advice Board 6 02-04-2005 09:33 PM
Shower wall and floor intersection(caulk vs grout) Aces High Tile Forum/Advice Board 1 11-27-2004 05:21 PM
