Unread 04-14-2019, 01:52 PM   #16
thedayrock
Replace Jacuzzi Tub with Shower
I can’t get to the trap. It’s too far under. Can i use a second trap or just hold off 12” away.
PS. The tar smell is strong. I need to cover it before it fills the while house.
Any tips?
Covered with plastic for now to hold smell down...
Derek
thedayrock is offline   Reply With Quote
Unread 04-15-2019, 10:56 AM   #17
thedayrock
Any word on the tar around the drain pipes in the slab? Do I need to stay from that or is it safe to clear out and re-plumb?
Derek
Unread 04-15-2019, 03:53 PM   #18
Ain't no such thing. Keep digging, Derek, you need to find that P-trap.
Don't understand the question about the tar. It's there, you'll need to dig through/around it, too.
Unread 04-15-2019, 03:56 PM   #19
thedayrock
I wasn’t sure what the tar was used for and whether it led to something else more problematic.
Is it safe to remove it and clear it out? Ever run into tar before?
It is strong smelling but I have it covered now and it is fine.
Rented a breaker that I had to return but have your recommended hammer drill on order. I don’t want to half-bake this project.
Derek
Unread 04-15-2019, 03:59 PM   #20
I have seen people use tar to seal the surface of the leave-out in concrete slabs, Derek, and I expect that's what you're encountering. Other than being messy, it's just one of the kinds of things that make remodeling fun, eh?
Unread 04-18-2019, 07:54 PM   #21
thedayrock
Ok, dug more today. More tar and groundwater. I am now 12” down and still not finding the trap.
What am I missing here? Is see a slight bend through the pipe but have dug where i would expect the P and there is nothing to be found
Derek
Unread 04-18-2019, 07:55 PM   #22
thedayrock
Derek
Unread 04-18-2019, 08:04 PM   #23
How old is your house, and in what state are you located?
Can you see down the pipe at all? If you run something down it, like a wire hanger, how far down will it go before you hit something?
Unread 04-18-2019, 08:07 PM   #24
thedayrock
Houston Texas built in 1978. Just put a coat hanger down - 22.5” is when it stopped.
I can see down the pipe and see a slight turn at about 12 inches but no up hump.
Derek
Unread 04-18-2019, 08:22 PM   #25
ZZZK
Are you sure there is no trap there? It kinda looks like we are just starting to see the trap in your pic but it is still too covered in mud. Anyway that trap was definitely code in 1978. Ive seen all kinds of illegal shortcuts in construction but this wouldnt save a plumber any money and carries a big risk. Perhaps he ran out of traps and had a deadline to meet? I still think there must be a trap somewhere in there. Im assuming the vent is what we see there so there isnt much more to dig until you hit your tee and know for sure.
John
Unread 04-18-2019, 08:26 PM   #26
thedayrock
If left the pipe open for days and no gas smell so I assume there is a trap. I just don’t know how dang deep I have to go. The ground water freaked me out a bit too but water table is high in Houston. Dug outside the house and ground water is at same level.
Do you run into things like ground water when digging that deep below slab?
Derek
Unread 04-18-2019, 09:27 PM   #27
If you'll add that geographic location to your User Profile, Derek, it'll remain permanently in view to aid in answering some types of questions.
I think I agree with John that what we're seeing in your photo is the beginning of the trap. Little more digging is still my recommendation.
Unread 04-19-2019, 12:23 PM   #28
thedayrock
Ok. Dug another 4”-5” and this is where I am. No sign of the trap and i don’t know how deep this is going to go. The ground water is making it a pain.
What are my options?
Derek
Unread 04-19-2019, 02:02 PM   #29
Derek, are you digging down, or further back under the wall? This last picture looks about the same as the one from yesterday.
Unread 04-19-2019, 03:06 PM   #30
thedayrock
I’m at a loss with the ground water. I’m nervous the hammer bit is going to bust through the pipe because I can’t see very well.
Any suggestions?
Derek
Jacuzzi to Shower Retro boulderz Tile Forum/Advice Board 6 01-09-2019 11:04 AM
Turning a jacuzzi tub into a tub/shower bzarna Tile Forum/Advice Board 3 07-23-2008 08:18 PM
Using Jacuzzi platform as part of shower seat, waterproofing personalt Tile Forum/Advice Board 5 09-28-2005 04:57 PM
KERDI shower system vs. Jacuzzi preformed shower pan saydee19 Tile Forum/Advice Board 9 05-05-2004 07:29 PM
basement jacuzzi tub/shower Boe Tile Forum/Advice Board 3 06-10-2003 08:58 PM
