Unread 02-21-2013, 06:24 PM   #1
ttown419
Ceramic Tile on Plank Subfloor?
Hello,
I am thinking about installing 12"X12" ceramic tiles to replace the (what appear to be original 1950) 1"x1" tiles currently in place in my 12'X5' bathroom. Underneath the existing tiles is a mud bed (1 inch thin-set, wire mesh, felt) which leads to a plank sub-floor. The bathroom is on top of a basement. Joist dimensions are in good condition, 9" height, 1.5" width, MOST are 16" on center (some are closer), and length is 15'. I used the Deflect-O-Lator and it shows that my sub-floor is not suitable for ceramic.
Is there a way to 'beef up' the floor before installing 1/2" plywood followed by backer board?
Any other ideas?
Thank you for any help you can provide.
ttown419 is offline   Reply With Quote
Unread 02-21-2013, 06:28 PM   #2
reefone
tile setter
you will need to add a wall or a support beam in the basement to cut down on the span of the joist or sister new joist along the old ones.
Jerry
tile setter 12yrs exp.
Unread 02-21-2013, 06:40 PM   #3
ttown419
Thank you, Jerry.
Would you recommend running the sister joists the full length of the current joists, or any other method besides adhesive and nails?
Unread 02-21-2013, 07:02 PM   #4
reefone
tile setter
sisters need to be at least 2/3rds of the middle of the joist. glue and screws is the way to go.
Jerry
Unread 02-21-2013, 07:03 PM   #5
To gain the required strength, you need to sister at least the middle 2/3'rds of the joists. More is better, but that is enough. That gives you a litle leaway to maneuver them in place, too.
Unread 02-21-2013, 07:10 PM   #6
ttown419
Thank you Jerry and Jim!!
Ceramic Tile over Plank Floor Sonny S. Tile Forum/Advice Board 17 09-18-2016 08:28 PM
Our first tiling project - ceramic tile over plank subfloor ChrisD Tile Forum/Advice Board 3 03-23-2012 08:02 PM
Tile over plank subfloor (again) stevemar Tile Forum/Advice Board 14 06-21-2011 10:25 AM
Kitchen Tile Prep Over Plank Subfloor Rich P Tile Forum/Advice Board 10 10-28-2009 06:17 AM
How do I tile over a plank subfloor? fishin49 Tile Forum/Advice Board 2 01-22-2007 03:26 PM
