Unread 01-17-2010, 07:43 PM   #1
coping skills
CSC
coping skills's Avatar
Luke's Bath Remodel
This is how I do a shower pan. I'm sure it breaks some rules, but the inspectors are okay with it. Posting it here to see if you guys approve.
I start by cutting 1" wide strips of 1/2" Hardie and back buttering them, then I put them around the perimeter of the shower and I nail them down.
Then I spread thinset over the entire area, from 1/2" thick on the edges down to regularly troweled thickness in the center.
Then I measure for the drain and transfer the measurements to....
-Luke
Quality Crapsmanship.
In love with liquids.
coping skills is offline   Reply With Quote
Unread 01-17-2010, 07:47 PM   #2
coping skills
CSC
A piece of backer!
Then I cut the backer and back butter it and squish it into the thinset. I then nail around the edges and around the drain, and tape my joints.
-Luke
Unread 01-17-2010, 07:52 PM   #3
coping skills
CSC
Then I check it out, I have the 1/4" per foot of required slope(actually a little better).
EDIT: I attempted to switch the order of these two pics, but was unable...
-Luke
Unread 01-17-2010, 07:55 PM   #4
coping skills
CSC
After this I will use a liquid waterproofing membrane, flood test, get it inspected and then put on another layer of hardie, and tile and what-not.
-Luke
Unread 01-17-2010, 07:59 PM   #5
My opinion, I don't like it. Cement boards are designed to be anchored down, not just thinsetted. You're a tileman, tilemen mix cement, or should. 5 bucks worth of cement and 20-30 minutes would have done the same thing but better.
You're gonna put another layer of Hardi over the pan?
Unread 01-17-2010, 08:24 PM   #6
K_Tile
Member of Million SF Club!!
Oh Boy!
Your log-in explains your methods, Coping Skills
I have seen that done with plywood for a preslope only but never a whole shower.
K_Tile is offline   Reply With Quote
Unread 01-17-2010, 08:35 PM   #7
yeah, and what-not
Unread 01-17-2010, 08:37 PM   #8
coping skills
CSC
Yes, I will put another layer or backer over the membrane so the pan will meet up with the top of the 3-piece drain.
Davy, I am not necessarily a tile man. One of sorts, but I work in all areas of construction/remodeling. The backer is mechanically fastened, but only on the edges and near the center.
Don't like it, eh?
-Luke
Unread 01-17-2010, 08:56 PM   #9
Brad Denny
Tile Contractor Nashville, TN
Brad Denny's Avatar
I vote to cut this out and discuss under the title of "Hardi Shower Pan".
Brad
Brad Denny is offline   Reply With Quote
Unread 01-17-2010, 09:26 PM   #10
Brad Denny
Brad Denny's Avatar
We know this is improper. Let's show why for those that may come along with the same situation. Luke came to the right place to learn a few things, we all gotta start somewhere.
Brad
Unread 01-17-2010, 09:27 PM   #11
coping skills
CSC
How do I go about doing that?
-Luke
Unread 01-17-2010, 09:31 PM   #12
Heres a start
http://www.johnbridge.com/how-to/deck-mud/
http://www.ontariotile.com/preslope.html
make some coffee its gonna be a long night.
Unread 01-17-2010, 09:40 PM   #13
The Kid
The Kid's Avatar
Ya Luke not a good set up at all. that second layer of hardi is gonna be saturated all of its life and really gonna be a breding ground for mold. IMHO it dont matter what the inspectors think cause Ive never met one who "truely" understood the principles behind a properly built shower.
Couple questions,
*How are you treating the wall to pan connection?
*What is being done at the weeps?
*Why, without any proper knowledge of shower construction are you selling a client a shower built in this manner, Or is this your own home?
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
Unread 01-17-2010, 09:42 PM   #14
coping skills
CSC
No Rick, how do I go about moving it?
I named it the Hackbacker pan for a reason; I am aware that most would consider me to be a hack.
EDIT: Yes, this is my home. I would not be able to, in good conscience, sell someone something I had not done at least a couple times before. I asked the inspector about it before I decided to do it.
I am putting hardi down to the pan and taping the corners, then painting on a membrane.
EDIT: Leaving the weep holes open.
-Luke
Unread 01-17-2010, 09:42 PM   #15
Brad Denny
Brad Denny's Avatar
Oh, BTW Luke. Don't go anywhere. This may get ugly, but we all want a successful install for you and your customers. Remember that.
I have asked cx to chop this out. Moderator hasta do it.
Brad
NH bath remodel designs Tile Forum/Advice Board 6 04-06-2009 04:01 PM
Bath Remodel CupanTilePaint Professionals' Hangout 1 09-04-2006 07:44 AM
Best Bath Remodel jbest Tile Forum/Advice Board 10 07-24-2006 01:55 PM
My last bath remodel....for now at least ilverme The Mud Box 11 01-10-2006 10:41 PM
(and another)....Bath Remodel chapperstx Tile Forum/Advice Board 9 01-01-2006 09:28 AM
