Unread 01-09-2004, 06:51 AM   #1
John K
Lasers
Can anyone tell me what Laser systems they are using?
I am in the market for a Laser square and I don't want no piece of crap.
John K
John K is offline   Reply With Quote
Unread 01-09-2004, 08:29 AM   #2
JJC
Tile Contractor
Hi John K
1/ Laser square is a Levelite (old model). Has a 10" protractor base to layout for diagonal etc. It saves a lot of layout time. and no chalk lines to snap, or worry about covering up with thinset.
2/ Rotary laser is a Lasermark by Berger. 360 deg. rotation at 2speeds, and will due a 45 and 22.5 deg. arcs. This I like because if there is a mirror in the room it doesn't bounce a distorted line off the mirror. Also there is a single verticle line. (use this for centering a decoratve "centerpiece" under a light etc.)
3/ Zircon plumb line. (self level)
4/ Laserjamb pole for the rotary unit. (expensive, but the quality is there)
Jim
Jim Carlin
Regional Director NTCA
JJ Carlin Tile Installations
Freeport, ME
JJC is offline   Reply With Quote
Unread 02-21-2004, 08:58 PM   #3
gpzrider
Tile Contractor -- Charleston, S.C.
I use a Strait-Line Laser Level; just a cheapie model that throws a line on the floor; but, it comes in handy sometimes. It works off two AA batteries. Available at big box stores.
Another is the SL-24 Laser Square. It's not cheap. It retails around $800. You can find a better deal if you shop around. It throws two 'chaulk lines on the floor that are 90* to each other. It also will put two straight horizontal lines on two walls or a dot on two walls. It has built in rechargeable batteries. It's handy. Could use a tripod.
A rotary laser would be handy also.
And don't forget a set of digital levels.
Nothing beats griding a floor, tho'.
Gary D Free
http://reliabletile.tripod.com/
gpzrider is offline   Reply With Quote
Unread 02-21-2004, 10:57 PM   #4
JC
I found that floor lasers are 20% percent helpful and 80% percent a waste of time...think about it other then checking a room for squareness once you have the marks you will spent all your time trying to get the laser aliened...and it pretty much takes two guys to do it too. I use the levelite it is everybit as good as the SL90 at half the cost...they have the same laser in them.
Got a 49 dollar jamb pole from Lowes and a self leveling Palm laser for walls and everything else. All the laser you will ever need. You can use it as a plumb bob by turning on the vertical making your mark then repositioning the laser over a few feet and making another mark leaving an X on the cieling or the floor.
Lowes has a 99 dollar version now if anyone is brave enough.
