Unread 04-23-2006, 01:20 PM   #1
Bigbobdallas
Spacer size? trowel ?
Went and got tile ceramic and getting ready to be sure I have all the stuff I need. I have 6X8 tile what size spacers for a tub/shower surrond. What size trowel do I need /width
Bigbobdallas is offline   Reply With Quote
Unread 04-23-2006, 01:30 PM   #2
Andrew21
You can use 1/4 x 1/4.. that should be ok..if not use the 1/4 x 3/8...should be fine
Andrew21 is offline   Reply With Quote
Unread 04-23-2006, 01:39 PM   #3
Madison Mike
Madison Mike's Avatar
Hey there Big Bob - 1/4x1/4 is fine, you might even go a little smaller, like 3/16x1/4 Vnotch if you want. I just started using wedge spacers for walls and love them. They're easy to adjust, just push them in or pull them out a little more. I used them for the first time on 12x12 travertine in a shower and they rock!
If you're going to be doing any floor tilewith spacers in the future, you can get 1/4" or 3/16" spacers and turn them on edge for thinner lines on the wall.
Madison, WI
Some days you get the beer, some days the beer gets you
Madison Mike is offline   Reply With Quote
Unread 04-24-2006, 08:45 AM   #4
Bigbobdallas
Grooves on trowel
Unread 04-24-2006, 09:24 AM   #5
They were telling you what size trowel, either 1/4x1/4 or 1/4 x 3/8 square notch or 3/16 x 1/4 V-notch. Use the smallest you can get full coverage with, so you don't get squeeze out between the tiles.
Spacing is up to you, but try for 1/8" or 5/32" on a test layout to see what you like.
