Unread 04-02-2013, 02:46 PM   #1
manitobski
What is the smallest tile allowed on the Schluter foam pan?
is 5/8" x 5/8" allowed?
manitobski is offline   Reply With Quote
Unread 04-02-2013, 03:03 PM   #2
Bodie Powers
Retired cabinet maker/remodeler
Bodie Powers's Avatar
I'm not aware of a minimum tile size.
I do know that round-bottom stones/pebbles are not approved by Schluter in that application.
Bodie
Bodie Powers is offline   Reply With Quote
Unread 04-02-2013, 03:25 PM   #3
I've not seen a limitation in the documentation. The reason there's one on Ditra is that the tile must be supported by a minimum amount of mortar to prevent a point load from 'tipping' the tile. Smaller than 2", and it might only be supported by a single plastic dimple, and not have any mortar underneath it that goes to the floor to transfer the load. Unless you plan to walk in the shower with spiked high heels, I doubt you'd ever have an issue.
Unread 04-02-2013, 03:52 PM   #4
manitobski
that's how i wrecked the last shower!!
Unread 04-02-2013, 04:24 PM   #5
Bodie Powers
TMI....lol
Bodie
Unread 04-02-2013, 05:31 PM   #6
Seems like I remember a thread several years ago where a guy had a problem with small tiles on a Kerdi Tray. I believe we finally found out that he had the hole in the plywood too large and the Tray didn't have good support around it.
Unread 04-02-2013, 08:23 PM   #7
dhagin
That might be a good question for their tech support. Suggest sending an email.
Let us know what you find out.
http://www.schluter.com/internationa...ess.aspx?id=13
dana
Unread 04-03-2013, 05:41 AM   #8
Executive Flooring
Executive Flooring's Avatar
I rarely use the trays simply because I know a mortar bed will hold up to even the a fat man.
The other reason is that I came across this video quite a long time ago where it was smaller tiles and it freaked me out a bit. From that point on, I swore I would never use small tiles on the foam.
Ray
MA/NH Home Remodeling
Executive Flooring is offline   Reply With Quote
Unread 04-03-2013, 07:08 AM   #9
Ray, there's a thread on here somewhere that was started by the fella that made your video. Don't think there was any definitive conclusion about his particular problem, but I believe it was narrowed down to a probable support problem in his subflooring.
Schluter folks were scheduled to visit his job and observe the tear out to make a final decision, but the guy elected to do it himself before they were scheduled to arrive. Wasn't the cleanest resolution of a problem we've ever had and then, as I recall, he made that video and continued to complain about the product.
While I'm not much of a fan of that, or any other foam shower floor product for other reasons, I don't think there is any demonstrated functional problem with their use.
Unread 04-03-2013, 09:09 PM   #10
manitobski
To CX, if there is no problem with the system then why don't you like it? Is it just a purist, nostalgic posterity thing for you or are there any real drawbacks?
Anthony
Unread 04-03-2013, 09:40 PM   #11
1. Foam trays are expensive.
2. The foam tray may or may not be the same size as my shower footprint, therefore requiring that I cut off and throw away some of the very expensive foam or I have to extend the foam with deck mud, or both.
3. The drain location in the foam tray may or may not be in the same location as the drain in my shower, possibly requiring more cutting and fitting and/or extending.
4. The foam tray requires that my subfloor be near perfectly level before installation, frequently requiring some leveling and flattening of the subfloor.
5. The slope of the foam tray may or may not actually be the required 1/4" per foot and any unlevel condition in my subfloor, no matter how slight, may further exacerbate that condition.
6. Any cutting of the perimeter, or extending of the perimeter of the foam tray will result in the perimeter not being level and adversely affecting the appearance of my tile installation.
7. The foam tray is not as substantial as a floor made of deck mud.
That's just off the top of my head.
Other than that I like'em fine, but not a single one of the above limitations applies to a deck mud shower floor.
On the plus side, the foam tray is lighter.
Just a personal preference.
Unread 04-03-2013, 10:47 PM   #12
IF the tray fits, and the drain is exactly where it's needed for it, the tray can be faster since you can install the Kerdi immediately after setting the pan down and hooking up the drain. That doesn't happen often. And, deck mud does go in pretty fast once you get the hang of it (depends on how handy you are) and is LOTS less expensive. Deck mud is cheap enough where you could practice and make lots of trials before you'd get to the cost of the tray...but, again, if speed is critical, and it fits, it works quite well. Lots of people here have made a successful deck mud base for their conventional and Kerdi based showers their first time out, so it shouldn't be considered magic. Now, doing one in say 1/2-hour takes some real skill, though! Your first would likely take you 3x as long at least (can't take too much longer, or the stuff sets up).
Unread 04-09-2013, 07:40 PM   #13
manitobski
fair enough
Anthony
Unread 04-09-2013, 07:53 PM   #14
Anthony,
We've even had some gen-you-wine wimmin types make their own mud shower pans. We're sure you can do this.
Just ask Wendy.
Unread 04-10-2013, 09:32 PM   #15
manitobski
i dont count women as a lesser sex and ive also done my share of mud pans
Anthony
Smallest Violin in the World... Lazarus The Mud Box 0 01-09-2011 11:27 AM
Kerdi Foam Shower Pan Adhesive Question vtcrusade Tile Forum/Advice Board 6 12-30-2010 11:05 AM
Limited Wall Tile Size/Weight allowed by the International Building Code mzablah Professionals' Hangout 2 05-04-2010 11:09 AM
Are tile DIY'ers allowed to cry? help please myrph Tile Forum/Advice Board 14 10-03-2009 09:33 AM
Foam preslope, pan, and curb?! duneslider Professionals' Hangout 17 05-05-2007 11:21 AM
