Unread 06-14-2012, 07:11 AM   #1
KFINN59
Haze on Porcelain Tile
Recently installed porcelain tile on top of outside bar and grouted as usual....Polyblend grout was used and regular process to clean grout after set up was followed. Now there seems to be a haze on top of tiles that will not come off...have washed 3-4 times since. Any suggestions on how to remove/clean tiles?
Thank you
KFINN59 is offline   Reply With Quote
Unread 06-14-2012, 07:24 AM   #2
pwgsx
pwgsx's Avatar
50:50 water and vinegar will take it right off. Happened to me on pretty much the same tile, same grout and on a outside kitchen area.
Phillip
pwgsx is offline   Reply With Quote
Unread 06-14-2012, 07:54 AM   #3
Kevin, you might wanna start by typing haze into the Advanced Search and asking for Titles. Couple hundred discussions of the problem in all of its many forms out there.
Unread 06-14-2012, 09:17 PM   #4
teeitup
Licensed Tile Sealing Contractor
Kevin,
Something else to check out just in case: If your grout is new and is a darker color you might want to try a smaller spot with less vinegar and use a white buffing pad, it will not harm the tile but will possibly allow you to use a more dilute mixture and that will protect grout color particularly on uncured grout joints.
http://www.tilesealing.com/grout_cleaning.htm
Mike Norman, CTC :-)
teeitup is offline   Reply With Quote
Porcelain Tile haze from thin set? Need opinions, it is even stumping DalTile. chinookgirl Cleaning, Restoration and Sealing 3 10-14-2011 02:36 PM
Removing haze from porcelain Johnny Drama Cleaning, Restoration and Sealing 2 02-03-2009 08:10 PM
grout haze over porcelain tile jerry1967 Tile Forum/Advice Board 1 04-21-2005 07:57 AM
porcelain Tile just laid. Help with haze Olaf Cleaning, Restoration and Sealing 2 02-23-2005 10:38 AM
Haze on polished porcelain Angela Cleaning, Restoration and Sealing 1 01-03-2005 11:12 PM
