Unread 01-15-2021, 02:13 PM   #1
J L McCoy
Ditra instead of felt
I'm building shower dry pack floor base and have extra Detra available.
Dry pack is for Kerdi membrane water proof. Would using Detra and no wire as vapor barrier UNDER dry pack instead of plastic/ or felt with lath be a bad thing?
I checked my drain position and preslope will work.
Jeffrey
J L McCoy is offline   Reply With Quote
Unread 01-15-2021, 02:35 PM   #2
I trust we're talking about Schluter Ditra, Jeffrey?
The purpose of the polyethylene sheeting or roofing felt under the drypack over a wood framed subfloor is to prevent the wood from sucking the moisture out of the mortar before it has a chance to cure properly. It is not intended to be a vapor barrier or even a vapor retarder, just a moisture barrier.
Ditra would be serious overkill for the application and I don't think it would serve the purpose of the expanded metal lath you should have there. But it's your shower and you can certainly do it in whatever manner you feel comfortable with.
'Fraid I don't unnerstan that at all.
Unread 01-15-2021, 04:19 PM   #3
Welcome to the forum, Jeffrey.
If you're installing a Schluter Kerdi shower, you won't have a pre-slope, but just one single mud bed that incorporates the Kerdi drain.
Unread 01-15-2021, 05:11 PM   #4
J L McCoy
I am using kerdi Membrane with a mud pack base. My choice of words are wrong.
Ditra I miss spelled.
I have ditra about 5x5 ft piece that I will never use. I was thinking Ditra alone as moisture barrier for dry pack. Or possibly Ditra with metal on top stapled to sub floor.
Don't have any felt but I do have heavy plastic, if it was your shower would you get and use felt, plastic, or use up Ditra
Jeffrey
Unread 01-15-2021, 05:26 PM   #5
Ditra, is not designed for that. The Ditra won't hang on to the dry pack like lath will. A couple plastic trash bags stapled down will keep moisture away from the wood. No one knows if Ditra alone would cause a failure but why take the chance? If it failed, it would be a costly repair.
Unread 01-15-2021, 05:38 PM   #6
J L McCoy
Listening and will use felt
Jeffrey
Unread 01-15-2021, 07:38 PM   #7
As said, the plastic or roofing felt is there to help prevent the subfloor from sucking too much moisture out of the dry pack before it can cure properly...it doesn't take anything fancy. Pretty much any plastic material should work. Once the stuff has cured, it really doesn't provide any subsequent purpose.
Durock over ditra felt? Crackedtile15 Tile Forum/Advice Board 4 10-02-2020 06:15 PM
Can I use redgard if I use felt NoviceJeff Tile Forum/Advice Board 6 07-14-2013 05:32 PM
15# Roofing felt vs ASK Hammy Professionals' Hangout 4 01-05-2011 09:51 AM
roofing felt + CBU? Wrenn Tile Forum/Advice Board 21 12-15-2007 11:55 PM
red rosin or felt? Chucky Tile Forum/Advice Board 6 07-02-2007 12:19 PM
