Unread 09-04-2011, 09:09 AM   #1
Interior Tile Solutions
Interior Tile Solutions's Avatar
Nylon Brushes ???
Does anybody know where I can buy nylon brushes in bulk for cleaning thinset out of the grout lines ? I'm tired of buying the small packs of three for $5.00 and think buying them buy bulk would be cheaper in the long run...Thanks in advance for your help.
Robert D.P II
Robert
Your Friendly Neighborhood TileMan Making Your Tiling Dreams Come True One Piece At A Time...
https://www.houzz.com/pro/interiorti...tions/__public
Interior Tile Solutions is offline   Reply With Quote
Unread 09-04-2011, 01:14 PM   #2
koihito
A person, like you.
koihito's Avatar
I don't know where you would buy in bulk, but why are you using so many? I've been using the same two for several years...
Nate
www.mikoskiconstruction.com
Unread 09-04-2011, 02:46 PM   #3
The olny ones I can find down here are junk...What are you using ? Let me find out !!!
Robert
Unread 09-04-2011, 03:44 PM   #4
what type of nylon brushes are you talking about and why are you "brushing" thinset out of your joints ?
Unread 09-04-2011, 03:56 PM   #5
cci
Try www.Mcmaster.com.
Search hand brushes. They have a huge selection.
Ships the same day.
Good luck
chris
cci is offline   Reply With Quote
Unread 09-04-2011, 05:06 PM   #6
tileguynky
Brushing thinset out of the joint?
For the occasional grout joint clean out, I use a sponge cut in half at an angle. Gives a nice point to clean out even very narrow joints.
Unread 09-04-2011, 05:16 PM   #7
I did learn back in the day when setting mosaic in fresh mud or even thin mosaic
or glass you can use a brush and a bucket of water to wash the thinset out.
but on regular tile I dont have that problem with the proper trowel.
Unread 09-04-2011, 05:31 PM   #8
koihito
A person, like you.
koihito's Avatar
Mine came from Lowes and I guess they have lasted because they don't get used much. Like Greg, a sponge does most of the work and the brush only sees action with very tight joints. I general I don't need to clean thin set out of the joints...
Nate
Unread 09-04-2011, 07:06 PM   #9
Mountain Tile
Pashley Tile
I use a toothbrush for cleaning out the joints, then wipe with a sponge. Get them at the dollar store. They cost " One Dollar "
Chuck
wwwpashleytile.com
Mountain Tile is offline   Reply With Quote
White Nylon pads (brushes, sponges) 1925 Home Cleaning, Restoration and Sealing 1 05-10-2010 09:57 PM
Advice needed concerning nylon pads and orbital sander... ehuesman Tile Forum/Advice Board 1 01-04-2008 06:49 PM
Polishing/Antiquing brushes Shaughnn Professionals' Hangout 10 05-06-2007 07:57 AM
