Unread 09-11-2004, 07:10 AM   #1
justin savage
Question curved shower wall
have a customer with a curved shower wall -new construction-ideas,suggestions.backerboard,or something with schluter-tips onbending whatever to the curve. thanks
justin savage is offline   Reply With Quote
Unread 09-11-2004, 07:18 AM   #2
Hi Justin, I'll move us to the Pro Hangout.
1/4 in sheetrock is usually used to create radius walls. The studs have to be fairly close together -- 4 to 6 inches apart. You can dampen the sheetrock before hanging it and use two or three layers. You could let that dry and then apply Kerdi.
I would float the wall, but I'm a mud man. If you have no experience with wall mud, use the sheetrock.
Unread 09-11-2004, 11:31 AM   #3
Davestone
Florida Tile & Stone Man
And i would add, you'll probably need to plumb the walls and add numerous spots of thinset to plumb it up otherwise you'll be in trouble lining up the tile as you go around and around and around
http://Davestonestile.com
Unread 09-11-2004, 12:16 PM   #4
justin savage
Talking
thanks john,dave
the shower is a 3 waller,2 straight the third curved shuold be fun.would you up charge extra for the curve and how much if so.thanks for the info.justin
Unread 09-11-2004, 12:51 PM   #5
Davestone
I would add 25-30% to my regular wall price,if it's not a mud job but i'm cheap
Unread 09-11-2004, 01:50 PM   #6
e3
wedi board , or one of the foam boards are supposed to work good for radius walls.
Eric
Noble Company
Unread 09-11-2004, 10:01 PM   #7
Man, it would take a bushel of those special fasteners.
Unread 09-12-2004, 04:18 AM   #8
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
Nows a good time to learn Mudwork.You'll spend more time on this one,but you should learn to Mud radius's if your going to be a tileman.
Charge more and expect to earn less on this particular job.
Read everything in here you can find on Mudding walls(i recall we discussed Mudding radius walls about a year or 2 ago extensively in the hangout here)
You'll become a better tileman in the end
Unread 09-12-2004, 04:11 PM   #9
I agree with Todd this time. Mud it out and make sure everything stays plumb.1500.00 extra otta be enough.
Unread 09-12-2004, 07:38 PM   #10
RandyL
Tile Setter
Send a message via Yahoo to RandyL
Would a radius wall still be at 16"o.c ? Are there any other special things to do when building a radius wall?
GID'DAY!
I FEAR NO BEER! (except Grolsh....yuck)
RandyL is offline   Reply With Quote
Unread 09-13-2004, 02:23 PM   #11
tileguytodd
Check out this thread.It was a little over a year ago we went through this.The guy had never done it and he did a fabulous job.Take heed and pay attention so you dont lose money
http://www.johnbridge.com/vbulletin/...adius+wall+Mud
Unread 09-13-2004, 04:36 PM   #12
RandyL
Tile Setter
Ha!
GID'DAY!
Unread 09-13-2004, 06:27 PM   #13
Randy, like John said the studs are normally 4-6 inches apart instead of 16. This is helpful, gives you plenty to nail to no matter which way you decide to install it.
Unread 09-15-2004, 08:05 PM   #14
charliemikeoh
curved shower wall
My husband did a ROUND bathroom a few years ago in polished marble. The house was an English Tudor wth a round turret the homeowners made into their Master Bath. I'm enclosing some photos (the proud wife!)
He put two layers of drywall and then mastic. Cut the 12" down to 4" for the diamond pattern.
charliemikeoh is offline   Reply With Quote
Unread 09-15-2004, 09:15 PM   #15
charliemikeoh
Okay ... "mud", "mortar" and "mastic". They all begin with "M" and stick stuff down. Keith says to clarify: it was cement MORTAR (*not* mastic).
