Unread 06-28-2009, 02:16 PM   #1
piastrelista
Tile contractor - Cement Mason
Making cut edge rough..
I have a rustic tile, and i am doing a boarder with a diagonal in the center. Whats a good method to rough the edges up on the diagonal cuts.
-Procopio-
piastrelista is offline   Reply With Quote
Unread 06-28-2009, 02:36 PM   #2
Muddman
Muddman's Avatar
Is this ceramic or stone?
Gregg
www.muddmandesign.com
Muddman is offline   Reply With Quote
Unread 06-28-2009, 02:47 PM   #3
dhagin
May try a rasp. Either steel or diamond depending on tile.
dana
Unread 06-28-2009, 02:58 PM   #4
use a grinder on the cut edge or a large bolt like a rasp.
might not look good if your tile is a glazed porcelain.
^^Check out our Blog^^
Unread 06-29-2009, 04:17 PM   #5
tracy d
tracy d's Avatar
Try a dull blade, it works for all of us even if we weren't trying!
tracy d is offline   Reply With Quote
Making cut rough-edge tile (like Cerdomus Pietra d'Assisi) look good miamicanes Tile Forum/Advice Board 12 06-04-2009 07:07 PM
Making A Chisleled Edge lovitall Tile Forum/Advice Board 4 11-02-2006 11:35 AM
how to rough-cut granite? Blayne Tile Forum/Advice Board 3 09-27-2005 04:01 PM
cut edge of tile Rob Tile Forum/Advice Board 3 04-07-2003 05:26 PM
Best way to take the cut edge off of porcelain ninemile Professionals' Hangout 9 02-04-2003 05:27 PM
