Unread 07-01-2007, 08:25 AM   #1
zimzum
how to find the inlet of hvac/furnace system?
I would like to try this stuff but I have no clue where to find the inlet(I h ave a heatpump)
BioZap is packaged in hermetically sealed plastic jars. Once opened, the foam slowly evaporates, usually over a period of 6 to 8 weeks. For prevention or for very light odors, one 1-lb. jar can cover 1,000 to 2,000 sq. ft. For worse conditions, use a couple of jars in the room or several jars in the house. Place a 2-lb. jar in the inlet of your furnace/HVAC system to eliminate molds in ducts and disperse a low level of the tea tree vapor through the house
bob ,a diy'er in lancaster pa
zimzum is offline   Reply With Quote
Unread 07-01-2007, 09:47 AM   #2
Davestone
Florida Tile & Stone Man
It's probably close to the unit, up high on a wall.
http://Davestonestile.com
Unread 07-01-2007, 10:02 AM   #3
zimzum
I though this mite be the area , the emty space below the coils and the filter?
Unread 07-01-2007, 10:35 AM   #4
Brian in San Diego
Brian in San Diego's Avatar
Zim,
You've found the right place. The inlet or return air side is the side returning the air from the living space. You could set the jars in the duct work below the coiling coil.
