Unread 01-07-2022, 12:00 PM   #1
JoeBoxer
Slow Poke
JoeBoxer's Avatar
Anyone used Laticrete Strata Heat Thermal Pack?
Just doing some radiant wire floor and stumbled upon this Laticrete Strata Heat Thermal Pack mortar additive. Looks like it is suppose to spread the heat more evenly and quickly into the floor area.
It will turn white mortar a dark charcoal color. Seems like it's possibly made of graphite (pencil led) and is non-magnetic. Name:  MVIMG_20220107_125710.jpg
Size:  69.5 KBName:  MVIMG_20220107_124800.jpg
Size:  39.6 KBName:  MVIMG_20211231_141318.jpg
Size:  46.2 KBName:  MVIMG_20220101_202444.jpg
Size:  67.2 KBName:  MVIMG_20211231_100356.jpg
Sent from my M2102K1C using Tapatalk
JoeBoxer is offline   Reply With Quote
Unread 01-07-2022, 01:31 PM   #2
Never heard of it, nor any similar product, Joe.
Unread 01-08-2022, 01:06 AM   #3
JoeBoxer
Slow Poke
JoeBoxer's Avatar
Guess I am on my own on this one.
Basic Direction:
1) Use full weight mortar. (50lbs type)
Does NOT recommend liteweight mortar. I gather reason being the performance would not be optimal as there is less mass for heat transfer. Or something like that.
2) Don't mix with polymerizing additives such as AdMix.
Most likely because the disolving plastic bag won't disolve properly with just Admix.
3) Add water and mix at lower RPM to avoid kicking up these extremely find dust.
These doesn't seem to really stain as it's a solid and not a coloring agent. But as always, test a bit on your natural stone tile to see if it stains.
I used it on travertine, and it cleans off well and doesn't stain these stone.
Unread 01-08-2022, 01:32 PM   #4
Tileworks
Tile Contractor -- Akron, OH.
Tileworks's Avatar
I use it all the time since we're an all-Laticrete company at the moment. I've often wondered what was in it. Could be a large black dye pack for all I know, lol.
I will use it when burying my wire. I might also use it when setting my tile. I've avoided it when using white mortar to set marble because I am concerned about staining.
- Bob
Classic Tileworks
http://www.classictileworks.com
Ohio Tile and Stone Installation Contractor in the Akron area serving Summit, Portage, Medina, Stark, & Cuyahoga counties in Northeast Ohio
Tileworks is offline   Reply With Quote
Unread 01-11-2022, 12:49 PM   #5
Sharon @ LATICRETE
Sharon @ LATICRETE's Avatar
Joe - STRATA_HEAT Thermal Packs shouldn't be used to install light colored stones as it will darken their color. A white mortar will become dark colored once mixed with thermal packs. Let me know if you have any other questions.
Sharon@LATICRETE
www.laticrete.com
Sharon @ LATICRETE is offline   Reply With Quote
Mixing Ditra Heat & Strata Heat components jutsin Tile Forum/Advice Board 5 01-10-2019 10:19 PM
Laticrete 254 platinum and strata mat kba1980 Tile Forum/Advice Board 8 02-25-2018 07:07 PM
Using Laticrete 3701 or regular dry pack deck mud John BP Tile Forum/Advice Board 7 02-08-2015 11:37 PM
Thermal break for under tile heat over slab World LLC Professionals' Hangout 34 04-10-2013 11:15 PM
Thermal break for electric radiant heat robertbtx Tile Forum/Advice Board 1 09-11-2010 08:42 PM
