Unread 07-28-2010, 01:10 PM   #1
andy911
Decoupling membranes for mosaic?
I'm planning to lay a 5/8" carrera marble mosaic on the floor - Ditra obviously is not appropriate in this case.
I don't think Nobleseal is available up here (Toronto) - what other membrane options are there?
Andy
andy911 is offline   Reply With Quote
Unread 07-28-2010, 01:13 PM   #2
ob1kanobee
ob1kanobee's Avatar
Wood or concrete floor?
Ben
Unread 07-28-2010, 01:41 PM   #3
andy911
Sorry - wood floor. Also, this is for the bathroom floor (ie. not a shower stall etc).
Andy
Unread 07-28-2010, 02:30 PM   #4
peteinsonj
why not ditra?
why would ditra not work under stone?
peteinsonj is offline   Reply With Quote
Unread 07-28-2010, 02:43 PM   #5
Pete,
Ditra has a 2"x2" tile size minimum
Unread 07-28-2010, 04:08 PM   #6
Trask
Oregon Tile Man
Trask's Avatar
Yep, no Ditra on mosaics..I like sheet mem. for crack isolation..especially Noble Poroducts but if they are not available Laticrete makes some fine liquid applied membranes.
Hydro ban by Laticrete would be a good choice over a tile appropriate subfloor. ( cement backerboard ect.).
Some Links:
http://www.laticrete.com/distributor...rproofing.aspx
http://www.laticrete.com/distributor...upression.aspx
There are a number of other crack isolation products available but none that I'm as familiar with or as comfortable using as the Laticrete products.
Trask Bergerson
Bergerson Tile and Stone
Astoria, Oregon
Unread 07-28-2010, 04:35 PM   #7
jadziedzic
Tony Dziedzic
Andy, Noble Company does have an online store, so they may be willing to ship to Canada. (The company is based in Michigan, I believe.) I ordered a seven-foot long section of NobleSeal TS and a gallon bucket of NobleBond EXT, and they only charged me $5 to ship the entire order.
Tony
jadziedzic is offline   Reply With Quote
Unread 07-29-2010, 06:20 AM   #8
andy911
Thanks. I would prefer not to have to ship since shipping across the border (especially for a bulky item) is usually quite expensive.
I'll look into the laticrete product more - my preference would be an actual membrane rather than a liquid though.
It sounds like perhaps Kerdi and Noble are the only two products that offer some amount of subfloor decoupling?
Andy
Unread 07-29-2010, 06:22 AM   #9
jgleason
jgleason's Avatar
Noble - yes
Kerdi - not so much
Unread 07-30-2010, 02:48 PM   #10
andy911
Does deflection calc depend on tile size?
For example if I want to install 5/8" marble mosaic and I use a flexible grout and Nobleseal membrane, how does that affect the max. deflection calculation?
Andy
Unread 07-30-2010, 03:43 PM   #11
No, and flexible grout is sort of a misnomer...true grout is primarily cement, which isn't very flexible. The modifiers can handle only a minor amount. Also, stone, because it has more natural imperfections, regardless of the size, still needs a thicker subfloor, and a stiffer floor structure in order to survive reliably.
Unread 07-30-2010, 07:04 PM   #12
andy911
Darn :-)
My joists are old-style 2x8's (ie. pretty much true 2" x 7.25) , 11' span 16" OC. The Deflecto-meter gives L/385. If I sister the joists up to 3.5" its up to L/673 - wondering if the membrane and the small tile size would give me some latitude.
I suppose I could sister the joists with metal plates instead. Or if I hang some perpendicular framing members would I be okay?
Andy
Unread 07-30-2010, 08:00 PM   #13
Edthedawg
Edthedawg's Avatar
Perpendicular running under/across them joists? Or just adding blocking between the joists?
The latter ain't gonna do a dang thing for you.
Ed
GO SOX!
Unread 07-30-2010, 09:16 PM   #14
Welcome, Andy.
It'll help if you'll ask all your project questions on a single thread so folks can see the history and what's been previously asked and answered. We can change the title to something more generic any time you'd like to suggest one.
The small mosaic tiles are working against you, rather than being of any advantage in dealing with subfloor deflection. Basically just a layer of grout with some little stones embedded in it, eh?
If you can determine the specie and grade of those joists, and are willing to sister with some good Doug Fir or equivalent, you may find your joist structure can meet specs for your stone floor.
Still hafta add a second layer of plywood subflooring, of course.
Unread 07-30-2010, 09:25 PM   #15
andy911
Thanks CX. Sorry about cluttering up the forum.
I'm thinking if I sister each joist with a 2x6 on both side, recessed down enough to put down the first 3/4" ply (or even a 1" ply) on them in between the existing 2x8s, that would have to give me enough strength, and also reduce my final floor height. on top I would do a 1/2" ply (or even 3/4" if I can get away with it) plus the nobleseal membrane.
How can I calculate if that will work?
Andy K.
Andy
Can I increase deflection calc. enough for porcelain tile? AJV Tile Forum/Advice Board 5 06-12-2010 06:34 PM
What size tile is most forgiving (deflection) DavidNOLA Tile Forum/Advice Board 3 07-17-2009 09:58 AM
Deflection calc DIYOHMY Tile Forum/Advice Board 17 05-31-2005 06:51 PM
calc needed on floor stiffness Mike_balt Tile Forum/Advice Board 1 04-21-2005 08:32 PM
Floor joist calc. Don Papenburg Tile Forum/Advice Board 7 01-01-2004 09:37 PM
