Unread 07-02-2009, 08:02 AM   #16
Edthedawg
Edthedawg's Avatar
Question Blue skies?
Architect friend likes the theoretical plan (plastic sheeting and 1/4" Hardi screwed right over the existing Durock, following a little more cleanup of the TEC).
I threw together an all-too-crude sketch of what I envision the resultant finish wall system to be.
Would enjoy your thoughts - thanks!
Ed
GO SOX!
Unread 07-02-2009, 09:42 PM   #17
dhagin
That'll work, and look good. I'd use urethane caulk at 1st bead and 100% silicone at tile/tub.
Phenoseal is, I believe, latex and not the best for wet areas.
For big gaps- make sure the specific caulk can be used. The label should tell you. Also, use a foam backer rod in the gap first and caulk over it. Width:depth = 2:1, max.
dana
Unread 07-03-2009, 08:12 AM   #18
Edthedawg
Edthedawg's Avatar
caulk selection
Dana,
Thanks for the feedback! I was kinda wondering about the Phenoseal myself, as I've seen it misbehave w/ some standing water issues, while do well in occasional wet areas, like around sinks and vanity backsplashes.
I've also had 100% silicones fail after a couple years, and needless to say, this isn't really an area I look fwd to having to dig out and re-caulk anytime soon...
Will continue to do my homework tho - thanks again!
Ed
GO SOX!
Unread 07-03-2009, 08:16 AM   #19
Hammy
Hammy's Avatar
IF there is plastic behind the existing backer board, then you install more plastic then 1/4" BB. you are potentially creating a what is know as a moisture sandwich. IF you insist on creating such a sandwich just use a liquid membrane over the existing BB you already have. Neither option is a perfect world and neither are industry standard. and ARE NOT RECOMMENDED.
Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
Unread 07-03-2009, 10:33 AM   #20
Edthedawg
Edthedawg's Avatar
moisture sandwich
so are there some options like cutting or hole-drilling some large openings thru the existing walls (behind the new plastic sheeting & BB) to ventilate those spaces?
thanks - this is exactly the kind of thing i was concerned about...
Ed
GO SOX!
Unread 07-04-2009, 07:39 AM   #21
Hammy
Hammy's Avatar
You could take down the existing board and start over. Opps, you didnt want to hear that again. Hammy
PS this can be done with a little fore-thought and not damage the tub. Not much different than installing new board after tub was installed. Cut a piece of plywood same size as tub. put carpet on top of tub edges, lay plywood on carpet and go to work. Just do it right this time.
Unread 07-04-2009, 04:37 PM   #22
dhagin
Good catch on the 2 layer of plastic, Hammy. I agree that this could be problems and that drilling a series of small holes could help alleviate the so-called moisture sandwich issue.
Properly prepared and placed 100% silicone, used on materials it was designed for should not fail 'after a couple years'. IMHO, there were likely other problems that caused the silicone to fail.
dana
How would you install this? Trask Professionals' Hangout 57 05-29-2009 05:43 PM
How would you install this? tilelayer Professionals' Hangout 11 10-10-2008 02:08 PM
Swanstone Retrofit Shower Base Install Advice and some hints on Warmly Yours Install cjmartin315 Tile Forum/Advice Board 11 04-05-2007 05:52 AM
Which install is better? likry Tile Forum/Advice Board 1 01-26-2006 10:44 AM
Can I install cibach Tile Forum/Advice Board 3 04-27-2005 02:15 PM
