Unread 06-04-2009, 07:33 AM   #1
lati_cz
michal
NOBLE shower bench
I need to build large seat in my next shower project. I noticed NOBLE makes prefab shower benches, has anyone worked with it? What do you think?
http://www.noblecompany.com/Products...9/Default.aspx
lati_cz is offline   Reply With Quote
Unread 06-04-2009, 07:46 AM   #2
ddmoit
ddmoit's Avatar
I have no personal experience with them, but I would not hesitate to use one based on Noble's reputation alone. I think a few folks around here saw them at the Coverings trade show and were left with a favorable impression of them.
Dan - a DIYer in SE Tennessee
Unread 06-04-2009, 08:36 AM   #3
Rob Z
Guest
Posts: n/a
Hi Michal
We have installed several of each type. Let me know what questions you might have and I'll try to help.
PS since starting with these benches, I haven't built any block and mortar benches.
PPS Daltile sells all of this stuff as well as being available online.
Unread 06-04-2009, 08:50 AM   #4
lati_cz
michal
Hi Rob,
They’re not cheap. But if I count the time for framing, waterproofing, kerdi etc. I think I’ll save $, time, wood…. Leak proof too.
Is it compatible with Kerdi? Does it sit on the sub floor or I thin set it to finished shower floor (kerdi)?
BTW. I talked to my schluter rep. yesterday, he told me they’re coming in few months with new product. No more kerdi. Just new Schluter tile boards, caulk the corners, seems, screws…. That’s it.
Thanks Michal
Unread 06-04-2009, 09:05 AM   #5
Rob Z
Guest
Posts: n/a
Michal
The solid benches can sit right down on the pan liner in a bed of mud. If you are doing a kerdi shower and have the mud floated for the floor, then you could likely sit the Noble bench down on the mud with thinset under it. We usually use medium bed material to set the bench.
Thinset is used to bond the bench to the wall, and it will work with any sort of membrane that is already on the wall.
You can cover this thing with Kerdi if you wish---thinset sticks to it well....but Idon't think you need to because the bench itself is waterproof.
We added a bench once to a shower that we had already set the tile and grouted (customer changed their mind). We bonded the bench with thinset to the tile and then caulked the perimeter with Latisil.
Unread 06-05-2009, 06:23 AM   #6
lati_cz
michal
thanks Rob,
I'll go ahead and order it. I'll post some pics later.
Michal
Noble Bench Information wanted flazoom Tile Forum/Advice Board 6 05-16-2009 06:46 AM
Is Kerdi or Noble in a tub/shower overkill?? liz-o Tile Forum/Advice Board 7 12-08-2007 08:56 PM
Kerdi shower and Noble niche bikemike Tile Forum/Advice Board 6 05-02-2007 05:59 AM
Noble Shower Curb and Misc liner Questions surfcaster Tile Forum/Advice Board 7 04-22-2007 07:31 PM
"Better Bench" shower bench installation tlandry Tile Forum/Advice Board 2 07-01-2004 07:18 PM
