Unread 05-10-2021, 04:47 PM   #1
Buck01
Wet Saw Blade Drift
I am seeking tips to prevent blade drift when cutting 45 degree miter on 12x24 tiles with wet saw. Prefer to use wet saw if possible vs cut with grinder. Thinking of trying multiple depth cuts to see if this helps. Recs welcome. Have new P4 blade but drift is still a problem
Buck
Buck01 is offline   Reply With Quote
Unread 05-10-2021, 06:53 PM   #2
Drift is most often caused by mid-alignment of the blade & tray....or the blade is not uniformly sharp.
Have you looked into alignment fixes...or sharpening the blade?
Unread 05-10-2021, 08:56 PM   #3
Buck01
Thanks Tool Guy. I know blade is sharp. Will double check alignment
Buck
Unread 05-10-2021, 10:02 PM   #4
smifwal
could be that you are pushing too hard and the blade can't cut as fast as you are pushing, causing the blade to deflect
Unread 05-10-2021, 10:28 PM   #5
Snets
Professional Weekend Warrior
Snets's Avatar
In my limited experience, making multiple passes in depth works. The finished edge cut is all you may see, if you can get that correct, with no drift, you are well on your way to a perfect finish, even if you have to grind below that where it will be hidden with grout.
Snets
My FIRST Kerdi Shower Project
Always look in the LIBERRY
Unread 05-11-2021, 05:03 AM   #6
What Bubba said. Make sure you're getting good water flow on both sides of the blade. Sometimes the hose on one side will get partially blocked causing that side of the blade to wear more.
Also, some blades are made thinner and more flimsy than others. I've seen that problem with thin blades.
They make sharpening stones for blades. I've always used a yellow fire brick for this. The type that mason's use for the firebox of a fireplace. 4 or 5 rips thru the brick usually helps expose new diamonds.
You say you have a P-4, what brand is that?
Unread 05-16-2021, 11:53 AM   #7
Buck01
Blade Question
Blade is a Pearl P4 mesh blade
Buck
Unread 05-16-2021, 02:15 PM   #8
Lazarus
Lazarus's Avatar
I can add that, doing a miter cut, in many cases, using a 10" blade is not the best. These blades tend to "wander" and "deflect" by a considerable amount.
I used a 10" blade for years and recently went over to a 7" blade with a reinforced hub and found it quite stiffer. Made the cuts flawlessly.
Sure, you can make progressively deeper cuts and that works pretty well...but, time consuming. I changed out from a "Diamondback" 10 saw to their 7" unit and never looked back...
Here is a video on that saw. On mine, I DID add some hard rubber, adhered to the tray to aid in holding the tile down and not slipping...
https://www.youtube.com/watch?v=q8R6eQmdKyk&t=8s
If you think hiring a professional is expensive, wait until you see the cost of hiring a amateur.
Unread 05-16-2021, 09:21 PM   #9
Because it's new or because you've sharpened it?
Also, can you tell us how hard your tile is? I ask because Pearl lists this blade for extra hard tile. That means that the matrix that holds the diamond bits is also very hard. If you’re cutting material that isn’t as hard as the blade intends, the tile will fail to grind away the matrix as the diamonds wear...meaning that it’ll go dull in a relative short amount of time.
Also, can you tell us if you’re sliding table is dead flat to the blade? Like, if you were to set the blade at 90 degrees and set the saw depth to make a light score on top of the tile, will it maintain this same depth the entire length of the tile? If not, the table is sloped from front to back. While this doesn’t affect the tracking of cuts made at the normal 90 degrees...it does mess up the straightness of a cut when you tilt the blade to 45 degrees.
diamond tile blade to sharpen carbide saw blade? argile tile Professionals' Hangout 5 02-19-2017 04:50 PM
I need a new blade figaro Professionals' Hangout 14 04-07-2011 08:05 PM
TM-75 blade spongebob256 Tile Forum/Advice Board 1 03-25-2008 10:50 PM
tile saw drift michael36 Tile Forum/Advice Board 1 02-07-2007 04:01 PM
blade Michaela Tile Forum/Advice Board 7 01-28-2006 08:34 PM
