Unread 05-05-2021, 09:06 PM   #1
Patflemming
Bad grout job - advice needed
Contractor is finishing up shower. I've been pleased with work ethic and attention to detail so far but I'm not too happy with his grouting.
I need other opinions. Am I too picky or should I mention this to the contractor? How could this even be fixed?
Pat
Patflemming is offline   Reply With Quote
Unread 05-05-2021, 11:50 PM   #2
It’s reasonable to expect that the grout joints are uniformly shaped. The examples you’re showing us are not relatively uniform. With cementitious grout, it is fixed by removing the grout to 2/3rds the depth of the tile and grouted again. If the grout is relatively fresh (up to about a day), it’s relatively easy to remove. It gets much harder thereafter, so time is of the essence to fix if it’s relatively fresh.
Unread 05-06-2021, 06:41 AM   #3
It's a bit sloppy, and would have been very easily fixed at the time he was grouting.
If the pictures you've posted are indicative of the whole job, I would want it fixed.
Unread 05-06-2021, 08:39 AM   #4
Lou_MA
Looks a bit rough. Does the whole job look like that?
Lou
Unread 05-06-2021, 11:24 AM   #5
Patflemming
Yes the whole job looks like that. It's not HORRIBLE but it's not like I was expecting. What should I reasonably expect as a resolution?
Product used was TEC power grout
Pat
Grout Cracking Advice Needed tbrim Tile Forum/Advice Board 9 08-01-2009 10:40 PM
Advice needed for removing grout soccermom201 Tile Forum/Advice Board 3 09-16-2008 01:58 PM
Advice needed for Epoxy grout Stew Tile Forum/Advice Board 8 07-04-2008 04:35 AM
Advice needed about grout golfhackk72 Tile Forum/Advice Board 10 05-29-2008 08:25 PM
expert tile/grout advice needed Unregistered Tile Forum/Advice Board 3 10-08-2004 09:52 PM
