Unread 03-14-2021, 12:31 PM   #1
CasperGhost
Trowel type and size for 12 x 12 marble tile sheet
What type notch and size trowel should be used to install 12" x 12" marble mosaic tile sheets for a kitchen backsplash. The tile sheets will be installed on painted drywall, which I will rough up prior to installing. I also plan on pre-sealing the marble sheets so none of the color from thin-set or grout blends into the tile.
I will attach pictures of the front and back of the tile sheets.
Thank you very much for any information you can provide. I just installed a few glass installations and the manufacturer specified the trowel type and size, but not for this tile.
Best,
Mark
Mark
CasperGhost is offline   Reply With Quote
Unread 03-14-2021, 02:55 PM   #2
Lazarus
Lazarus's Avatar
If the wall is quite flat, you might get by with a 1/8" square notched trowel. Press the tile in firmly with a grout float, then peel a sheet back and check for coverage. If marginal, go up one size,
Use white thinset.......
Unread 03-14-2021, 05:31 PM   #3
MesaTileworks
How big are the individual tiles? I’d do what Lazarus suggested and start with a 1/8” notch, then check to make sure you are getting adequate coverage.
MesaTileworks is offline   Reply With Quote
Unread 03-14-2021, 08:46 PM   #4
CasperGhost
The individual tiles are 1" x 4" on a 12" x 12" mesh sheet. Thanks for your help with this.
Mark
Unread 03-14-2021, 09:38 PM   #5
MesaTileworks
Yeah, I’d start with a 1/8” square notch. Check for coverage. If too much, thinset will squeeze up too high in the joints, too little and you’ll peel up the tiles and see <80% coverage.
Unread 03-14-2021, 11:48 PM   #6
CasperGhost
Thank you very much for your suggestions!
Mark
Mark
Unread 04-18-2021, 03:41 PM   #7
CasperGhost
Alkaline resistant mesh tape on kitchen backsplash?
I have just finished putting Densshield backer board up prior to installing my mesh backed marble tile mosaic. I have four small seams where the boards meet. Is it necessary to use mesh tape and thinset on these seams for a kitchen backsplash? Certainly in a shower where we are trying to waterproof the wall, but what about for a kitchen backsplash?
Thanks for your recommendations, I went through a lot of work to this point and want to do the rest of it the correct way.
Best regards,
Mark
Mark
Unread 04-18-2021, 04:32 PM   #8
Mark, it'll help if you'll keep all your project questions on one thread so folks can see what you're working on and what's been previously asked and answered. A moderator can give it a more generic title any time you'd like to suggest one.
Not sure why a fella would install DensShield on a kitchen backsplash, but if that's what you've got, that's what you'll use, eh? The mesh tape and thinset mortar at the backerboard seams is to create close to a monolithic backer material rather than for any waterproofing purpose and I would recommend you treat your seams as instructed by the manufacturer. Since you'll not be applying any waterproofing membrane (I presume), you can do this filling and taping as you set the tiles if you want. That can help in eliminating the "speed bumps" sometimes resulting from treating the seams and letting them cure before setting tile.
Unread 04-18-2021, 06:05 PM   #9
CasperGhost
CX,
Thank you for the response! I will tape and thinset the seams as you suggest, and I like the idea of doing it as I tile to avoid any potential humps which was a concern of mine. An no, I do not need to add any waterproofing membrane for the backsplash - and I think the Densshield will more than do it
Thanks again.
Mark
Mark
sheetrock mesh tape vs. durock mesh tape hamlet_jones Tile Forum/Advice Board 2 03-27-2012 08:53 PM
Alkaline resistant tape Houston Remodeler Professionals' Hangout 76 12-12-2011 12:32 AM
alkaline resistant fiberglass tape vs. regular fiberglass tape Andruxa Tile Forum/Advice Board 6 05-04-2007 06:12 PM
Can't find alkaline resistant tape for cbu Greg Thomas Tile Forum/Advice Board 32 05-02-2006 07:00 PM
alkali resistant tape jkloepping Tile Forum/Advice Board 2 02-21-2006 11:01 PM
