Unread 02-04-2021, 05:36 PM   #16
magnum
How to waterproof window sill made out of Kerdi Board?
Hi. I built a window sill out of Kerdi Board. I am trying to figure out how to waterproof the sill ends and corners. I tried different configuration folds of Kerdi membrane and Kerdi corners but none of it seem to work. Do you have any ideas on how to waterproof that?
http://imgur.com/a/evgqjel
patryk
magnum is offline   Reply With Quote
Unread 02-04-2021, 06:38 PM   #17
redlude97
Kerdi fix and kerdiband should be used instead but I would be worried that the tile will end up being too thick for that window surround
Hai
redlude97 is offline   Reply With Quote
Unread 02-04-2021, 06:50 PM   #18
Welcome, Patryk.
It'll help if you'll keep all the project questions on one thread so folks can see what you're working on and what's been previously asked and answered. A moderator can change the title to something more generic if you'd like to suggest one.
It'll also help if you'll attach photos from storage on your computer so they appear in your post and remain a permanent part of your project thread.
Unread 02-04-2021, 07:25 PM   #19
magnum
Oh, Im sorry, I created a new post for each issue. I will try to keep it organised here.
I will try to find a way to waterproof it with the Kerdi Band. Can I apply Kerdi fix on the band if there is any edge not being overlapped?
The window surround is another issue, since the tile will end up 1/8" over the window. I am thinking if its better to trim the drywall or trim the tile end under an angle and cover it with silicone.
patryk
Where to start tiling ssatterw Tile Forum/Advice Board 3 06-16-2008 07:40 PM
A little help before i start tiling Mustangous Tile Forum/Advice Board 32 10-17-2007 08:23 PM
Few Questions before i start tiling my bathroom WTBtile Tile Forum/Advice Board 4 06-14-2007 09:05 AM
almost ready to start tiling... hap Tile Forum/Advice Board 1 05-14-2004 03:25 PM
Where to start tiling DavidT Tile Forum/Advice Board 13 05-29-2002 05:04 PM
