Unread 02-01-2014, 08:03 AM   #1
Hammy
Hammy's Avatar
A bad crack isolation method
This found in FineHomeBuilding. Silicone caulk for crack isolation.
http://www.finehomebuilding.com/how-...oor-tiles.aspx
Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
Unread 02-01-2014, 08:06 AM   #2
MNTileGuy
Central Texas Tile Guy
But, hey, he's done it for all those years without failure!
It's a shame that a "reputable" magazine like Fine Homebuilding would have an article like that. That's about right on par with rolling out duct tape.
Brad Bressler
Bressler Tile and Stone
www.bresslertile.com
Unread 02-01-2014, 08:33 AM   #3
That must be some amazing caulk !!
Unread 02-01-2014, 08:41 AM   #4
HS345
Tile Contractor
HS345's Avatar
Tom Meehan, call your office.
The name's Greg
Unread 02-01-2014, 08:47 AM   #5
If we're just trying to keep the tiles from bonding in that area, I'm wondering why we'd bother with the mesh tape. Just as easy to eliminate the silicone, too, and simply not apply bonding mortar in that area if his "system" had merit.
Unread 02-01-2014, 09:33 AM   #6
Why do you bring up Tom Meehan? He had nothing to do with this. I actually invented that method.
Unread 02-01-2014, 09:58 AM   #7
HS345
Tile Contractor
HS345's Avatar
I was just kidding, I figured Tom could set 'em straight.
The name's Greg
Unread 02-01-2014, 11:25 AM   #8
Tiger pilot
Location: Atlanta Georgia, but working across North America
STANDARDS?, We don't need no stinking standards! I've never had a callback! Yes I do screen my calls, change phones regularly, and move frequently!, but not one complaint have I heard!
Steve
Steve Rausch
Professional Consultant to Tile Industry
Cell 404-281-2218
Rauschsteve@comcast.net
Tiger pilot is offline   Reply With Quote
Unread 02-01-2014, 11:31 AM   #9
jwmezzanotte
jwmezzanotte's Avatar
The mesh tape ties the two slabs together so they dont move. Its better than reinforcing steel.
The tile will also help hold the two sides together. Common sense.
Unread 02-01-2014, 12:21 PM   #10
dhagin
Think John forgot the [sarcasm] [/sarcasm] tags.
ps, anyone surprised this came outa florida?
dana
Unread 02-01-2014, 02:31 PM   #11
K_Tile
Member of Million SF Club!!
Shocking secrets, big manufacturers didn't want you to know....
Unread 02-01-2014, 05:34 PM   #12
Tiger Mountain Tile Inc
Here's another inexpensive tip that's in league with this one:
If you find that you have a squeaky subfloor simply spray WD-40 on the back of the tile before installing. PRESTO!
Do you think I can get that tip published in Fine Home Building magazine?
Unread 02-01-2014, 09:16 PM   #13
HS345
Tile Contractor
HS345's Avatar
I don't see why not Jim. They kin put yours right next to the silly-cone anti-fracking membrain article.
The name's Greg
Unread 02-01-2014, 09:49 PM   #14
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
Since they are basically a carpentry magazine I should submit the following and see how they would appreciate ignoring common sense on a subject they are experts in-
Preventing Upper Cabinet Failures.
"My grandfather was a carpenter from the old country who once told me that an ounce of prevention is worth a pound of cure, especially when confronted with the risk of installing upper cabinets to drywall.
There are numerous commercial products available that allow carpenters to install upper cabinets to stud walls. These industry approved fastening systems also known as screws require careful drilling, location of the studs or blocking and use of expensive power tools. Although these systems do effectively attach the cabinets to the wall they can be costly to do and and require skill on the part of the carpenter.
Over the years, I have found that the simplest, least expensive and most effective method of attaching upper cabinets to drywall at the job site is to use a few globs of construction adhesive like Liquid Nails but on high end jobs I recommend upgrading to PL. Just spread carefully the adhesive on the back of the cabinet, squish into the drywall and brace until the adhesive cures.
I've used this quick, inexpensive method successfully on uppers cabinets without failure. At least until the homeowner filled the cabinets with dishes."
The ironic thing is that even an approved crack isolation membrane 4" wide is not doing anything. The only reason he hasn't had a failure is because those cracks didn't move. Doing absolutely nothing would have been just as good or better than this method.
I hope one of our experts from the NTCA will contact Fine Homebuilding and their comments on the subject will be printed.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 02-01-2014, 10:10 PM   #15
jwmezzanotte
Isaac
That stuff is pretty expensive and overkill. Whats wrong with hot glue?
crack isolation jwmezzanotte Tile Forum/Advice Board 6 02-28-2012 10:51 AM
Crack Isolation Method? ccrow Tile Forum/Advice Board 8 07-28-2010 01:36 PM
crack isolation ben-e Tile Forum/Advice Board 5 10-17-2008 10:27 AM
Crack Isolation tf2 Tile Forum/Advice Board 8 04-15-2008 07:55 PM
crack isolation Yersmay Tile Forum/Advice Board 5 04-29-2007 05:26 PM
