Unread 11-01-2010, 10:14 AM   #31
andy911
Complications with getting the new joist members underneath existing finished space that is not being opened up - I'm working from above in this case. Plus some hvac bulkheads in the way, not directly below the floor to be tiled but further along inside the middle 2/3rd of the joist.
Andy
andy911 is offline   Reply With Quote
Unread 11-01-2010, 10:15 AM   #32
bbcamp
I'm gonna disappoint Brian, but I dunno what might happen if you sister only the area you intend to tile, or just beyond that area. I suspect that the lack of rigidity will cause an early failure (cracking tile or grout), but I can't tell you how bad it will be, how soon it will happen, or even if anything bad will happen at all. Engineers avoid unsolvable (or difficult to solve) problems by making some simplifying assumptions, then designing the structure based on the assumptions made. Joists with differring cross sections are difficult to solve, so we don't use them in residential construction.
Unread 11-01-2010, 10:36 AM   #33
andy911
Thanks Bob. I'm just curious as to how the unsistered portion could possibly cause the sistered portion to internally deflect. I suppose there is a levering effect there.
I'll try to get the sistering beams under the floor as far back as possible though. I'm calculated to L/1035 deflection so I'm overbuilding to a certain extent. With 1.5" of ply plus 3/8" slc im thinking it'll be okay.
Andy
Unread 11-01-2010, 04:09 PM   #34
andy911
Well a bit of good news - turns out most of my joists are 12" OC, with only 3 cavities being 16" (ie. the ones that support the bathtub, which I had replaced earlier so I had them opened)
So double sistering is way overkill for most of the floor, but I still need to do it to recess the first course of plywood.
Andy
Unread 11-02-2010, 09:32 AM   #35
andy911
Looks like I have a bit more height room than I thought - maybe I don't need to recess the first layer of ply.
If I double sister the 16" OC and single sister the 12" OC, can I run a 3/4" sheet and a 1/2" sheet of ply? (then 1/4" to 3/8" of slc embedding a heating mesh)
Andy
Unread 11-02-2010, 10:14 AM   #36
bbcamp
Sounds OK to me. (You intend to sister at least the middle 2/3s of the span, right?) Add a decoupling membrane or a antifracture membrane (on top of the SLC), and you should be fine.
Unread 11-02-2010, 10:58 AM   #37
andy911
I'm going to do my best - I don't think I'll get 2/3rds but I should get the middle half ie at least 8 feet from the ends.
Does the thicker ply sheet go down first or second? (or does it matter)
Andy
Unread 11-02-2010, 11:02 AM   #38
bbcamp
Thicker sheet first. You screw the second sheet into the first, so you want something thick to engage as many threads as you can.
Unread 11-02-2010, 12:21 PM   #39
andy911
Sounds good. One last question - can I sister the joists with PL premium and screws (instead of nails which are technically better for shear)? And what is the course/pattern for the screws in this case?
Cheers
Andy
Unread 11-02-2010, 12:56 PM   #40
Edthedawg
Wannabe Engineer Old-house-nik DIY'er :)
Edthedawg's Avatar
PL and decking screws are exactly what I'd be using here. No nails. Screws every 6 - 8", and I stagger the layout top-third, bottom-third.
Ed
GO SOX!
Pleased to have helped design and build many of the residential projects featured here: http://www.tandtdev.com/portfolio.html
Edthedawg is offline   Reply With Quote
Unread 11-05-2010, 06:30 AM   #41
andy911
Quick question - with 1.25" of total ply, do you think I need to put insulation under the subfloor for a heated floor? Or, at least, can I get away with a foil insulation between the two sheets of ply?
Andy
Unread 11-05-2010, 06:36 AM   #42
Edthedawg
Edthedawg's Avatar
You're always benefitted by adding insulation in the joist bays, unless there's latent heat in the space below that you'd prefer to transmit more freely into your floor surface.
I wouldn't consider a foil layer embedded between the plywood layers to do anything productive, at all.
Ed
GO SOX!
Unread 11-10-2010, 01:03 PM   #43
andy911
Hi, I have two questions about anti-crack membranes:
1)are there any membranes rated to go right overtop of the heating wires that would still provide a reasonably smooth surface for the mosaics? (ie in order to skip the slc step)
2)alternatively, any objections to using the laticrete hydroban roll-on membrane overtop of the slc?
Andy
Unread 11-10-2010, 01:26 PM   #44
bbcamp
1) No. Wires and mats are lumpy and they need embedment in something to spread the heat. SLC or thinset, then a membrane.
2) None that I know of. Contact the manufacturer to be sure.
Unread 11-10-2010, 01:57 PM   #45
andy911
Thanks. It does appear their products are compatible with a heated floor according to thier directions, so that sounds like the best way to minimize height.
Cheers
Andy
Can I increase deflection calc. enough for porcelain tile? AJV Tile Forum/Advice Board 5 06-12-2010 06:34 PM
What size tile is most forgiving (deflection) DavidNOLA Tile Forum/Advice Board 3 07-17-2009 09:58 AM
Deflection calc DIYOHMY Tile Forum/Advice Board 17 05-31-2005 06:51 PM
calc needed on floor stiffness Mike_balt Tile Forum/Advice Board 1 04-21-2005 08:32 PM
Floor joist calc. Don Papenburg Tile Forum/Advice Board 7 01-01-2004 09:37 PM
