Unread 08-09-2007, 06:48 PM   #1
TinyShock
TinyShock's Avatar
Opps, Why does mine look like this??
Hi everyone, nice to meet ya...i have been lurking in the shadows for sometime now. Going through the liberry and reading different topics. Thanks for all the great info and help.
I was wondering what my next step would be after removing the old leaky pan. I hope the pic helps. I want to create my own pan with liner. Im just confused as to how the drain attaches to the trap. Do i need to fill that area around the pvc pipe?
TinyShock is offline   Reply With Quote
Unread 08-09-2007, 06:55 PM   #2
You'll need an ABS drain, I think. PVC is an off-white, ABS is black, different materials, so get the right drain. You'll need to fill in, but I'm not sure of the details. Have you read the instructions in the 'liberry'?
Unread 08-09-2007, 06:56 PM   #3
Davestone
Florida Tile & Stone Man
Yes, you would fill that hole,i use thinset around the inside edges, and wire and drypack, or usual concrete mix,then cut the pipe so the bottom half of your clamping drain is level with the slab and glue it on.They use a pices of cardboard or something to keep the concrete from damaging the pipe when pouring the slab.
http://Davestonestile.com
Unread 08-09-2007, 07:16 PM   #4
TinyShock
TinyShock's Avatar
Thank you for the replies...i will continue to go through the liberry for additional info...thanks again...and nice to meet ya
Unread 08-31-2007, 12:15 PM   #5
TinyShock
TinyShock's Avatar
additional reading
Well after I continued to read the various post from everyone sure enough I found several post that were in fact similar to my question. I will try to have concrete questions in the future.
Unread 08-31-2007, 12:36 PM   #6
ddmoit
ddmoit's Avatar
We'll be here when those questions come up.
How about giving us a first name to call you.
Dan - a DIYer in SE Tennessee
Unread 08-31-2007, 12:55 PM   #7
TinyShock
TinyShock's Avatar
Sure, Name is Brian...Nice to meet ya...
Just getting ready to fill that whole with ready mix concrete. do I have to put gavel and sand in or can I just use the ready mix. Also though I read something about using latex additive in place of water to bond with the old concrete is that correct...thanks again...nice to meet ya...
Unread 08-31-2007, 01:37 PM   #8
Ready mix is fine Brian, just get all the loose stuff outta the bottom of the hole, and make sure the bottom stuff is reasonably well compacted. You could also fill the hole a bit with gravel, therefore needing less ready mix, as well as bricks, rocks, -n other stuff. I hear that cats don't work so good so don't be tempted, least the spouse catches you eyeballing her prized Tabby.
When you do the pour make certain the height of your pour is equal to, or a little less than, the hight of the existing concrete. It's easy to add an 1/8 or 1/16 of height with a bit-o-thinset, not so easy to take the same away.
Finally, be sure your existing drain is high enough. Would surely be a mood hassle to fix that after the pour.
Unread 08-31-2007, 02:05 PM   #9
TinyShock
TinyShock's Avatar
hehe that was funny bout the cat...and she caught me...kewl deal on the replay...so i will make it a little less then the other concrete...the abs pipe is a little higher then the concrete as well...the bottom drain piece should be level with the concrete right...thanks for your help...nice to meet ya...
Unread 08-31-2007, 02:12 PM   #10
The height of the drain peice will be dictated by the pan you are using. I would really consult the pan instructions before mixing any concrete. Oh, wait - you mentioned that you are going to make your own pan? Would that be with a pre slope drypack, follow by membrane, etc? What type/brand drain do you intend to use?
Unread 09-15-2007, 07:37 PM   #11
TinyShock
TinyShock's Avatar
Question
Thanks for all the information. I decided to revisit the liberry for additional guidance on the pan construction. I have been reading Shannon's post. Tons of information with that post. Since my sub floor is concrete I decided to go with bricks for the curb.
How do I attach the metal lath to the bricks? Thank for any help. Brian (Tinyshock)
Unread 09-15-2007, 08:07 PM   #12
Welcome, Brian.
If you go to the UserCP above, find Edit Signature and enter your first name there it will appear in each post for folks to see.
You don't attach the metal lathe to the curb, regardless the curb material. You'll see the procedure in a thread in the Shower Construction thread in our whirl-famous Liberry whilst you're in there. You don't see it, sing out and someone will help you find it.
Unread 09-15-2007, 09:11 PM   #13
TinyShock
TinyShock's Avatar
Smile
Thanks CX, that big box store book is still in my brain. So I don't actually connected the lath to the bricks. Kewl. I just apply the mud. Thanks again.
Unread 09-15-2007, 09:39 PM   #14
jdm
jdm's Avatar
Just to be nit picky, ready mix is usually used to refer to concrete that is delivered and mixed by trucks. Those great big trucks. That might be a bit much to fill in around your drain.
Otherwise, Brian, just rid your mind of anything you read in a big-box book and stick around here. You'll get primo advice, and will never hear "Your receipt will print below the pin pad device."
jeff
Go Rutgers!
Unread 09-16-2007, 02:05 AM   #15
TinyShock
TinyShock's Avatar
Thanks dude, I have been tryin to help myself to the liberry information. So just making sure i got it. Pre slope, then curb, then membrane, then lath (not attached) over bricks, and then mub?
