Unread 08-27-2021, 08:05 AM   #1
wyerd
New to tiling- help with major problem
This is my first tiling project. It came out a lot better than I expected, but the problem I have is the uneven gap at the top of the tiles and the bottom of the cabinets. Do just fill it with grout? What do you all recommend that can be done to hide it?
This YouTube video shows it better.
youtu.be/lZHdCfdlH6M
Thank you,
Dave.
wyerd is offline   Reply With Quote
Unread 08-27-2021, 05:05 PM   #2
fabian55
Hi Dave, you won't be able to notice that uneven gap at the top. I did my kitchen before I needed any tile tools and only used the tile cutting pliers, yours looks perfect compared to mine and you cant see mine at all unless you are coming up and moving from the bottom cabinets for example.
I would not worry, I did fill mine up with the grout which did help out a bit. Seems your group is white, I would just fill it in and it should blend with the tile to make it less noticeable, maybe someone has better option..
Fabian
fabian55 is offline   Reply With Quote
Unread 08-27-2021, 06:45 PM   #3
We usually do a little measuring ahead of time to avoid that situation. A slightly larger joint in the layout would have made that go away. But, I also know that it's hard to think of everything. You would know next time.
All you can do is grout it in or install some small slivers. I agree with Fabian, if your grout is white, it won't be that noticeable.
Unread 08-27-2021, 07:29 PM   #4
wyerd
Thank you both for your recommendation. It’ll fill it in with grout over the weekend.
Thanks again.
Really need advice to solve a major tiling problem! rodgilbert Tile Forum/Advice Board 6 08-27-2009 12:51 AM
Major subfloor problem mapleleaf4ever Tile Forum/Advice Board 40 01-05-2009 10:49 AM
Major Grout Problem Nation Tile Forum/Advice Board 3 08-16-2008 04:09 PM
Major grout problem help neeeded Edison'smom Cleaning, Restoration and Sealing 10 08-30-2006 12:23 PM
major grout problem--help! tilevirgin Tile Forum/Advice Board 3 05-08-2005 08:54 PM
