Unread 12-20-2005, 07:45 AM   #1
chrisb5180
Greenboard in Shower
I am in the process of remodeling my bathroon. I finished sheetrocking the bathroom using greenboard. I have two questions. First, is it alright to use greenboard for the tub walla where I will be tiling. Second, is it alright to start tiling the walls without spackling.
chrisb5180 is offline   Reply With Quote
Unread 12-20-2005, 08:06 AM   #2
muskymike
muskymike's Avatar
Hi there, Chris I presume? Welcome! Greenboard is not a suitable surface for tiling on inna wet location. You will either have to use a membrane in the areas that it will get wet or take it out and use cbu.Click this info on greenboard.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 12-20-2005, 08:12 AM   #3
Dave Taylor
Dave Taylor's Avatar
What M Mike said Chris........
Glad he said it, Chris, cause my Christmas spirit was dragging just thinking of saying ya might need to consider backing up a bit and remove green board... at least from possible wet areas.
Dave T (DIY'er)
the net.
Unread 12-20-2005, 08:47 AM   #4
chrisb5180
Reply to Greenboard Advice
Hey guys,
Thank you so much for your advice. Just one more question. If my ceiling in the shower is 8 ft, do I need to replace the greenboard with cement backer board as well?
Unread 12-20-2005, 09:10 AM   #5
Dave Taylor
Chris
The consensus I see here is.... no you don't Chris..... if yer not thinking of tiling it.
If ya got a bath exhaust fan and it gets used.... a shower ceiling is even less of an issue but.... you may wish to use a better quality primer and paint as you finish it.
If yer thinking of tiling the ceiling then..... proly revert back to what M Mike said.
Hope this helps and.... sorry fer the bad news earlier. You took it well :--)
If the professional folk here got a different take on this, Chris.... listen to em.
Dave T (DIY'er)
the net.
Unread 12-20-2005, 09:10 AM   #6
Andrew21
Originally Posted by chrisb5180
Hey guys,
Chris,
Thats what I'm wondering. I don't know if I should go all the way up or go with CBU then greenboard. ughhh...decisions decisions...
Andrew21 is offline   Reply With Quote
Unread 12-20-2005, 11:28 AM   #7
Mike2
Greenboard on a ceiling would be OK in there only if your joists are spaced 12" OC. Otherwise I'd remove it and use 5/8" wallboard instead.
