Unread 06-07-2021, 11:01 PM   #1
skorte
Stone Discoloration
We have a brown discoloration on the stone around our fire place as shown in the pictures below. We used a magic eraser (probably a bad idea) to get rid of it a few months ago but it has come back in the same spot. Any ideas on what is causing this and suggestions to clean it would be greatly appreciated. Thanks!
Stewart
skorte is offline   Reply With Quote
Unread 06-09-2021, 08:20 AM   #2
Hi Stewart,
I'm guessing it's moisture. If it were on only one piece of stone I would say it might be iron oxide, rust, in the stone makeup.
Unread 06-09-2021, 05:41 PM   #3
I agree with John, not sure what else it could be.
After a heavy rain, I'd open the fireplace doors and look inside with a flash light, especially on the left side. You might see moisture in the firebox or it might be running around the box.
Unread 07-28-2021, 11:44 AM   #4
ragtop69gs
ragtop69gs's Avatar
Is this a wood burning fireplace with a metal firebox or is it gas with metal box. Do you have a flue cap on top of the chimney?
Jay
Patriot Guard Rider
http://www.patriotguard.org/
'69 Buick GS400
'47 Diamond T 509
"We have been doing so much with so little for so long, pretty soon we will be able to do everything with nothing."
ragtop69gs is offline   Reply With Quote
Floor discoloration pray4surf Tile Forum/Advice Board 3 09-30-2010 12:23 PM
grout discoloration thecleaner Tile Forum/Advice Board 5 12-11-2009 08:16 PM
Grout Discoloration Danno Cleaning, Restoration and Sealing 6 06-21-2004 10:35 PM
grout discoloration pete Tile Forum/Advice Board 7 02-16-2004 06:40 PM
Grout Discoloration eganjp Tile Forum/Advice Board 6 07-30-2002 04:58 PM
