Unread 07-23-2007, 02:12 AM   #1
steve_w
A ledge at the end of bathtub
Hi, this is such a great forum. wish i knew of it earlier. i am remodeling my bathroom and the new tub is slighly shorter than the wall space (length-wise)
so I am thinking about pushing the tub all the way to the left side and on the right end of the tub (<. 1 foot space), instead of drywalling it all the way to the ceiling, I am going to build a ledge so that I can put soap/ shampoo ... etc. How high do you recommend I build this ledge? If I am going to build it to the same level as the tub, is there any special thing I should watch out as far as tiling/ water proofing is concerned? I am worried this extra space may accumulate water, which makes easier for water to seep through. Thanks!
steve_w is offline   Reply With Quote
Unread 07-23-2007, 08:47 AM   #2
Mike2
Hi Steve, glad to have you with us.
Building a shelf might work and it can be waterproofed with a liquid membrane like RedGard. There may be other options as well.
When you say the new tub is slightly shorter, exactly how much is that? What does (<. 1 foot space) mean? Finally, does this tub also have a vertical wall flange at each end in front?
P.S. Here's a link to Custom's RedGard product, commonly found in the tiling section of most Home Depot stores. http://www.custombuildingproducts.co...er=pro&lang=en
