Unread 08-10-2004, 12:18 PM   #1
martmo
Bathtub Ledge - Waterproofing
Great forum! I have been lurking for sometime, but now have a couple of questions.
Our new bathroom will have a tub w/shower head. On opposite end of tub is a 9" ledge/deck that that is a little wider than the tub and is about 2" higher than tub. The ledge and tub surround will be tiled. I am concerned about water on the ledge.
Question: How should this be waterproofed?
martmo is offline   Reply With Quote
Unread 08-10-2004, 01:43 PM   #2
Treat that ledge like a shower bench. Build it extra stout, cover with plywood and backerboard, then use a paint-on surface waterproofing membrane like Redgard, or use Kerdi, a waterproofing membrane that is thinset to the walls. If you use Kerdi, you can skip the backerboard.
Do a search for threads dealing with benches.
