Unread 10-10-2021, 09:13 AM   #1
DIYourselfer
Water leak in concrete wall...
I have water dripping from the second floor ceiling which is concrete. Above it is a shower on the 3rd floor. The shower walls are tiled and the walls behind them are concrete. Is the discoloration on the tiles in the pictures below water damage? If so would the valve area be a good place to start opening the wall?
Steve
Subic Bay, Philippines
P.S.
This is a GREAT site and I want to thank the professionals here for answering our questions no matter how basic they are.
DIYourselfer is offline   Reply With Quote
Unread 10-10-2021, 10:29 AM   #2
Hi Steve, welcome back. Of course we have a few questions before hopefully being able to answer your questions. When you say concrete walls and floor, do you mean a poured concrete or do you mean it was installed using a mud bed type installation? Do you have extra tiles to replace those with? Do you have access to the other side of this wall?
Moisture does look to be getting into the tiles from the back side but that doesn't mean they are damaged. The moisture would dry out of the tiles if the water source can be repaired. So, I wouldn't bust out any tiles yet until you can get a better idea of where the leak is.
Once you know the problem is with the pipe in the picture, cut the grout around that tile and chisel it out. Cutting the grout first helps avoid chipping the neighboring tiles.
Unread 10-10-2021, 05:20 PM   #3
DIYourselfer
Davy,
The walls are poured concrete and the pipes are in the wall. My main issue is to stop the leak which is causing damage on the second floor. I don't have replacement tiles but I do have access to the concrete wall behind the shower. Judging by the pictures, do you think it is the valve that is leaking?
Steve
Steve
P.S.
Unread 10-10-2021, 06:03 PM   #4
Steve, we don't have enough information to make that call. If there's a shower head above the valve then it could be leaking in the line going to it. If that's the case it would only leak when the shower is being used. Does that seem to be the case or does it seem to leak all the time? Is there any visible water escaping lower in the wall?
Unread 10-10-2021, 08:17 PM   #5
Can you take a few steps back so we can get a perspective of the shower head and any other fixtures? That would help us guess at locations of possible plumbing pipes.
Unread 10-11-2021, 06:52 AM   #6
DIYourselfer
Here are more pictures. Thanks
Steve
P.S.
Water leak fpeters151 Tile Forum/Advice Board 1 07-22-2016 03:35 PM
water leak outside of tub mryjane Tile Forum/Advice Board 2 07-31-2012 09:09 PM
water leak question Karly Tile Forum/Advice Board 11 04-18-2010 07:58 AM
Old Concrete Shower Wall leak Eric007 Tile Forum/Advice Board 13 03-08-2010 09:41 AM
slick tile, water leak? ikey Tile Forum/Advice Board 6 05-23-2007 10:57 PM
