Unread 10-08-2021, 09:13 PM   #1
Pixy2548
Black marble table polishing issue
Hello everyone, I have some etch spots and I just tested wet polishing pads on electric drill (100 to 6000 grid) and I did use water, it does makes it smooth but now I have circle swirled all over... What am I doing wrong? Will try to attached some pictures.
And I I think I can already feel a dent in a table. Am I going to make a hole in a table top?
Tetiana
Pixy2548 is offline   Reply With Quote
Unread 10-08-2021, 11:45 PM   #2
Welcome to the forum, pixy.
What grit are you currently at that you see swirls?
Unread 10-09-2021, 01:40 AM   #3
When you get it polished, you'll likely see a dent in the reflection. You have to do a bigger area than just where the etched area was. And, the area will probably need to get larger with each grit.
You're sure this is marble and not granite? That's a whole different animal.
Unread 10-09-2021, 12:16 PM   #4
Tile & Stone Guild
King Of Tile
Need a pic of the stone to help with final results. Expecting this to be like sanding a piece of wood in simplicity is a mistake.
Jeff
Tile & Stone Guild is online now   Reply With Quote
Unread 10-09-2021, 06:37 PM   #5
Each finer grit removes the deeper scratches from the coarser pads, and then makes new ones. Eventually, you may need a polishing compound and a buffer pad versus sanding pads.
Unread 10-20-2021, 08:04 AM   #6
Pixy2548
hello every one, here is some pictures. You can see there few white spots, and scratches too... i did use all the grids and was hoping that scratches will disappear, but no.... And i do have a buffing pud too (will try to send an image)
Tetiana
Unread 10-20-2021, 03:02 PM   #7
As you change grits, you want to clean the area off well in between to ensure there's no loose particles left over, or you'll be spreading those around and scratching it anew. Then, before you can go to the next finer grit, you have to get ALL of the previously created scratches removed (and you'll be making finer ones that will need to be removed with the next finer grit). You keep doing this until you find the results satisfactory. You may need to end up with a polishing compound, but keep in mind, that, too, needs to be finer than the last grit you used, or it won't do anything.
So, with the coarse grit, remove all of the scratches, clean things off, switch to a finer one, and keep repeating until you're happy...
When the panel was made, they ground the entire surface flat...because you're not grinding the whole surface, you'll be making a depression at least the depth of the scratches you're trying to remove, and as mentioned, you may see that as a distortion.
Unread 10-20-2021, 05:13 PM   #8
Tile & Stone Guild
King Of Tile
A variable speed grinder is what’s needed for this, pad needs to stay flat continuously and using a drill isn’t the best tool. You really need to do the whole table, rule of thumb is when you think you got all the scratches from the previous pad go so more, and some more after that. Only way to get this back to factory is oxalic acid at the end.
You would be better off sanding with a orbital sander to 200 grit and putting a enhancer to get the color back.
Jeff
Unread 10-21-2021, 01:37 PM   #9
Pixy2548
So I should start with 100 grid again and just do it longer? can I press on it a little? I am scared to make a hole in a table ....
so how do i know that it's time to move to another grid?
I thought that any kind of acid will destroy table?!!!!
should I use enhancer to get the color back after grid #3000?
as I understood there should be no visible scratches after grid #800-1000 , correct?
Tetiana
Unread 10-21-2021, 05:39 PM   #10
Tile & Stone Guild
King Of Tile
You won’t make a whole in the table. Yes you need to start over with 100 grit. After each pad squeegee the marble off and let it dry. If you see any swirls from previous pad you have to keep going. Each pad is removing the scratches from the previous. No downward pressure let the pad do the work.
The acid is made for polishing stone to a high polish, but it will also etch it if left on too long or splatters are left to sit. It’s part of the process.
Jeff
Unread 10-21-2021, 10:14 PM   #11
Pixy2548
Tile & Stone Guild , Thank you for reply!
But still even after I use #1500 grid I will see the circular marks and no shine, correct?
....no scratches , but some marks (just like on the photo, on the edges I did use #3000, may be wasn't doing it for too long but I see the circular motions even on this pictures)
Tetiana
Unread 10-22-2021, 12:13 AM   #12
Tile & Stone Guild
King Of Tile
If you still see scratches above 1000 then you have to start over. You will see swirls but not scratches. Especially on the lower grits keep it wet, helps keeping a rogue diamond scratch.You can try the buff pad going wet to dry but the powder will give a better and quicker result.
Jeff
Unread 10-22-2021, 06:46 AM   #13
Pixy2548
Do I have to use both the oxalic acid and the color enhancer? or just the acid will do all the job?
Can I get oxalic acid from Walmart? as a powder? it's says "Excellent Rust Removal, Iron Stain Removal" not sure if I can use it on marble? or is it need to be a specific one?
how should I use acid? sprinkle on aria, add some water, use a paper towel and rub by hand (or a buffer pad)? and then few days later use a regular marble sealer?
Tetiana
Unread 10-22-2021, 10:01 AM   #14
Tile & Stone Guild
King Of Tile
Wait until you see how you do polishing before you buy it, it’s specific to the stone industry Walmart doesn’t carry it.
Jeff
Polishing Ultra Black Honed Granite Tile to Polished finish TDHUNT Cleaning, Restoration and Sealing 11 06-11-2018 03:38 PM
Polishing Black granite issbob Cleaning, Restoration and Sealing 1 07-09-2013 10:52 PM
Black Granite Polishing BobbyS Cleaning, Restoration and Sealing 16 12-24-2009 11:15 AM
Another Granite polishing question... Absolute Black Krizzle Tile Forum/Advice Board 2 03-28-2007 06:55 PM
black granite table top Diane Cleaning, Restoration and Sealing 8 04-25-2004 04:50 PM
