Unread 10-05-2021, 03:09 AM   #1
TileGuyCanada73
Looking for pictures of large rooms with 12*24 tiles in a 1/3 offset brick pattern
I'm really having a hard time visualizing this. Most of the pictures I can find online either have a 50% offset brick pattern or a 1/3 offset staircase/step pattern. This is a diagram showing the pattern I am looking for but I'd like to see it on a big floor with big tiles. Have any of you done an install like this?
Steven
TileGuyCanada73 is offline   Reply With Quote
Unread 10-08-2021, 01:31 PM   #2
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
This came up very first when I googled it. This isn't alternating like your pic. But it's your other layout choice. Your local tile showroom will likely have a large area covered this way.
Most of us would agree that 1/3 offset looks better than 50/50 when it comes to large tile on the floor
Sent from my SM-G986U1 using Tapatalk
Travis
It's just a clever handle.
Unread 10-08-2021, 03:43 PM   #3
Shaklee3
Here's my bathroom. It's not huge, but it's 1/3 steps.
Cliff
Unread 10-08-2021, 07:32 PM   #4
I usually run my 1/3rd pattern like your last post shows, not crazy about the pattern in your first post.
Unread 10-08-2021, 07:59 PM   #5
3 of these are in hotel and the other is my buddy's kitchen
I did the pattern you are looking for but on a plank. The customers really liked it that it had a pattern going down the middle, yep that is what I was going for I said...
Unread 10-08-2021, 08:28 PM   #6
I, too, prefer the single-direction stair-step shown in post #3 rather than shown in post #1.
Unread 10-10-2021, 03:21 AM   #7
TileGuyCanada73
Thanks all. Looks like those are all the staircase pattern. I wonder why no one does the brick pattern...
Steven
Unread 10-10-2021, 05:00 AM   #8
Platypus
If your question was not rhetorical:
The 50/50 running-bond "brick" pattern does not work well with large tile since tile is almost always a bit curved, with a hump in the middle (end-to-end, one-dimensional hump). The closer the ends are to the center of adjacent tiles in the next course, the more lippage you will have since the ends sit lower than the centers, and 50/50 maximizes the difference. The 1/3 offset, or something similar like a random offset scheme that hits the zone between about 20% to 35% reduces this inevitable lippage while still providing some pleasing and functional overlap.
If there was no overlap, you would have continuous mountain ranges and valleys running along your ugly stacked pattern. [Yeah, that's right, stacked is simply ugly no matter if the tile is large or small, vertical or horizontal].
If you were asking why nobody likes the 1/3 offset that is not like a staircase as shown in the first post, it is probably the same reason that a stacked layout is ugly. There are certain rules of proportion that work, and some that do not. These rules are quite real, easy to quantify, but hard to explain why they please the eye or not. You could search for the answers by using an ancient secret: the Golden Ratio. There are undoubtedly other ratios that "work", and 1/3 is a weak but still effective substitute for Phi. Some ratios simply do not work, just as certain musical chords are pleasant to a majority of people and others are simply nerve-wracking. These can be quantified easily enough, but the underlying why they are generally pleasing or repulsive still remains a mystery.
Gerry
Platypus is offline   Reply With Quote
Unread 10-12-2021, 01:12 PM   #9
redlude97
Here is my 12x24 with a 1/4 offset. My tiles were heavily bowed so 1/3 had too much lippage for me. I did a stairstep layout too but didn't like it as much.
Hai
redlude97 is offline   Reply With Quote
cutting rectified tile & brick pattern for large tile nancyaustin Tile Forum/Advice Board 12 05-28-2014 08:46 PM
Pictures of pattern using 12x12 and 2x2 (or close to it) BimmerRacer Tile Forum/Advice Board 10 01-09-2009 06:47 PM
Pictures of 1st 2 Rooms KHF Tile Forum/Advice Board 9 12-16-2005 08:32 AM
Aligned tiles vs. Offset kathykoontz Tile Forum/Advice Board 15 01-25-2005 08:19 AM
Pictures of Tiled Rooms? MN Newbie Vannilee Tile Forum/Advice Board 12 10-26-2004 01:51 PM
