Unread 05-23-2009, 08:39 AM   #1
tht828
Toilet flange problem
After demolition of the existing floor and mud base my toilet flange now sticks up 2" above the plywood. I was plannning on installing backer board then the new tile. Combined that will be about 1" How do I handle the 1" the flange will extend above the new floor?
tht828 is offline   Reply With Quote
Unread 05-23-2009, 09:05 AM   #2
HotinOKC
HotinOKC's Avatar
Hi!
PVC piping or cast iron?
If PVC, you could probably just cut off a inch then glue on a new flange.
I don't have much experience with cast iron, so if you have that, someone else should chime in.
Mark
Support our Troops!
http://www.dav.org
HotinOKC is offline   Reply With Quote
Unread 05-23-2009, 10:25 AM   #3
Deckert
After your demolition, what do you have left? Make sure your framing and subfloor is sufficient for tile before you adjust your drain. Use the Deflecto tool at the top of the page to check your numbers. Also, what sort of tile are you planning on putting down?
Brannigan
HeenanGC.com
Toilet Flange stephenpinn Tile Forum/Advice Board 9 05-05-2008 12:05 AM
Toilet flange James Aiello Tile Forum/Advice Board 3 02-16-2008 12:46 PM
Toilet Flange Acamar Tile Forum/Advice Board 9 07-17-2006 10:48 AM
toilet flange blueboarder1 Tile Forum/Advice Board 15 11-13-2005 09:14 PM
toilet flange - first or last momb Tile Forum/Advice Board 4 03-04-2005 07:09 AM
