Unread 01-16-2020, 06:50 AM   #1
shovelhd
Subfloor/underlayment options for ceramic tile reno
I am replacing around 300 square feet of ceramic tile in a kitchen, hallway, and foyer. The old tile was 1/4" thick, laid with thinset on on 1/4" luan stapled to the subfloor, and it's all ripped out (that was a joy). The subfloor is 3/4" T&G plywood. The joists are 2x10 SYP on 16" centers, reinforced with wood cross braces. Deflecto roughly L/824 and L/555.
I am down to the subfloor, and I'm looking for advice on how to build up the new floor. I am going with 1/4" ceramic tile, 12x12, contractor grade. The low match points are 3/4" hardwood. I see a few options that will work:
1. 1/2" CBU
2. 1/2" plywood underlayment tiled directly to it
3. 3/8" plywood and Ditra
4. 1/4" plywood, and either Ditra or 1/4" CBU
I've never worked with Ditra. I tiled an upstairs bathroom with 1/2" Durock and 12x12 tiles and it came out great. No issues. I'm leaning towards going with what I know.
Any advice is appreciated.
Chris
Chris
shovelhd is offline   Reply With Quote
Unread 01-16-2020, 08:55 AM   #2
Welcome aboard Chris.
Given what you've described I don't see any reason you'd need anything more than the 1/2" CBU atop your 3/4" subfloor. Of course you'll have to embed that CBU in thinset mortar and screw it down per the manufactures' fastening schedule.
If total height is an issue you can also use 1/4" CBU. But whatever you do, you don't want 1/4" ply in the mix.
Underlayment options chrykies Tile Forum/Advice Board 4 03-17-2014 04:58 PM
Subfloor deflection for ceramic tile install (no T&G) - options? dglex Tile Forum/Advice Board 10 02-26-2014 08:24 PM
Ceramic Tile Subfloor and Underlayment M_Bishop Tile Forum/Advice Board 25 07-30-2011 09:56 AM
Advice on subfloor and underlayment for ceramic tile and radiant heat babyruthjr Tile Forum/Advice Board 7 02-21-2008 12:35 PM
Subfloor options on concrete before installing ceramic tile Man In Black Tile Forum/Advice Board 2 03-28-2007 06:50 PM
